electric wiper motor installed today on the 55
Spent most of today installing a New Port electric wiper motor in my 55, it turned into a little hassle, this should have been a hour and a half job at most. There is one anchoring bolt that to me proved to be impossible to get started it's hidden behind the electric motor mount and is a feel only thing , with my fat body and stubby fingers getting in the way it was not going to happen. I wasted three hours and all of my patience on that one bolt! I finally ended up putting a stud in that back hole and just slipped the mount over it, I later installed a nut and washer, this allowed me to bolt the near hole with out misaligned the far hole. If you ever do this modification use a stud then add a nut and washer at the last.This probably isn't very clear if you haven't seen a New Port electric wiper before but if you do this adaption remember this thread it may save you some time and frustration....Tedd
PS everything works as it should I'm not afraid to go out if it looks like rain now....
Thanks for the post Tedd! Since I'd like to do this conversion some day, I appreciate the feed back. It sounds like your projects work out just like mine, taking 2 to 3 times longer than I think they will.
Did you use their shaft extension for the stock **** and did that work out well? I believe you said you have the factory vacuum squirters and probably retained those.
Did you use their shaft extension for the stock **** and did that work out well? I believe you said you have the factory vacuum squirter's and probably retained those.
55 miketn, I didn't notice any shortness of stroke on mine,I wonder if our wiper blades are the same length? Mine travel from the bottom of the windshield to past center going both ways....Tedd
Thank you guys for posting about this! This is on my to do list also. I was worried about the batwing fit. Tedd using the stud is a great idea.
Rick
Rick
Mine go from center bottom to about 15 degrees past vertical. I would have thought they would go to like 30 deg. They work ok and I can see, but I would like them to have gone a little farther left. BTW. My air cleaner did hit. I am going to "modify" it. No big deal though.
Wow Tedd, you where not kidding about that rear screw it's imposible to get in. I just got mine in and had to use a stud to install as well . I also feel that the wires are a tad short for the 56.BTW, I'm to cheap to buy the extension so I came up with this to install the factory **** on the new switch. I filled it with solder drilled it and retaped the set screw hole using a 8-32 tap and installed the set screw that comes with the new ****
new switch in place
filled drilled and tapped with new set screw
new **** that come with kit and old set screw
installed
new switch in place
installed
Ya,I don't seem to be experiencing that problem and I haven't had to adjust anything to get full sweep of the wipers....Tedd
Tedd - I installed the Newport wiper motor yesterday. All the posts were a great help. I used the stud and added some length to the wires. The result was great! Everything works as it should.
Thanks to all that posted on this topic!
Rick
Rick
Greg Rogers
Apr 11, 2013 07:41 AM
oldspackrat
Nov 11, 2012 10:53 AM
Tedd Thompson
Mar 27, 2012 08:44 PM
