1955 Olds 4 barrel adjust with vaccum guage
The wiper vacuum motor feeds through the pump's booster; so that's not so good.
On the 4GC there is a full vacuum tap at the rear of the throttle body which connects to the pump's vacuum booster. On mine there is a "T" fitting; one side goes to the vacuum booster on the fuel pump; the other end has a plug which could be used for a vacuum gauge.
The only problem I'm having is remembering if that "T" fitting was always there from the start or if I added it somewhere over the life of the car to get some pure manifold vacuum to do exactly what you are proposing. Anyway look at the back of the throttle body part of the 4GC. Right in the center of the back there is a "tap" (1/4" NPT???) If there is no "T" fitting (the factory may have used an elbow), you could add a "T" which would make your task easier in the future.
Thank you Ozzie and Olds64. Running a PVC valve in line with out road draft tube and with power brake vacuum hose. Would have to find a fitting to run a third vacuum outlet. Will try the tach idea first.
As an alternative, if you can smell gas in the exhaust, it might be just about right!
Beau Dirt
Dec 27, 2021 03:02 PM
72delta88
Oct 10, 2016 07:47 AM
