1954 98 olds PS
Old Mar 25, 2016 | 08:00 PM
Gene Fettig's Avatar
1954 98 olds PS
Will the complete PS unit from a 1954 Olds. 98 fit into a 1955 Olds. without any modification
Old Mar 26, 2016 | 05:59 AM
Rocketowner's Avatar
I believe everything would be the same. Maybe someone can check it on Hollanders, but I don't think you will run into any problems. Just get the Pittman arm from the one with power steering. I changed one on a '54 Chevy, and had to go back and get the Pittman arm because we're different. Larry
Old Mar 26, 2016 | 06:10 AM
1954 98 ps
Thanks Iam Learning
Old Mar 26, 2016 | 06:52 AM
Ozzie's Avatar
I can't answer accurately because I've never done this, but I can tell you what Hollander says.
They say that '54 and '55 will interchange with the following note:
"Post and worm assembly, cross shaft assembly and housing assembly only. Not sold by manufacturer as a steering assembly."
They also say that the pumps are expected to interchange.
The spindles are the same '53-'56.
Tie rod sockets are the same '39-'60.
The lower arms for '54 & '55 show different part numbers. Interchange is not indicated.
Information on the upper arms for the '54 is not shown in my books.
('55 & '56 interchange)
The knuckle supports for '54 & '55 show different part numbers. Interchange is not indicated.
While I'm unsure about all the implications of the above, such is what's in the Hollander Manual 30th edition.
Old Mar 26, 2016 | 09:01 AM
Glad Ozzie was able to reach the old Hollander manual. I thought it would be an easy swap.,but I found out again that what "I think and a dollar will usually get you a Coke out of most drink machines ". Larry
Old Mar 26, 2016 | 09:23 AM
redoldsman's Avatar
Proud Viet Nam Veteran
There is a power steering sector and a pump on sale right now on ebay. They are listed separately but are both from the same seller. The prices are $150 and $75 respectively. That is a really good price on the sector and a fair price on the pump which includes the bracket. You can probably count on having them both rebuilt. Chip at Power Steering Services is the go to person for that. Here are the links:
http://www.ebay.com/itm/1954-Oldsmob...VWSPek&vxp=mtr
http://www.ebay.com/itm/1954-Oldsmob...hWSSEM&vxp=mtr
Old Mar 26, 2016 | 10:44 AM
1954 98 ps unit
Old Mar 26, 2016 | 04:22 PM
Ozzie's Avatar
Don't get too discouraged. The steering gear "assembly" in the Hollander can include everything involved in the steering of the vehicle all the way back to (and including) the steering wheel. So when somethings are excluded, they may be things that are not really needed in making the conversion. As the '54 and '55 are similar in many ways sometimes small modifications can get something to work. Best wishes.
Old Mar 26, 2016 | 05:15 PM
1954 98 Oids.
I sure thank you for the info not sure when you say about small modifications. Thanks again. Geno
jad717
Mar 24, 2010 02:05 PM
Kenn55
Cars Wanted
Jun 21, 2008 08:16 AM
loveolds
Oct 28, 2007 11:01 AM
ozoneblue
Jul 10, 2007 10:02 PM
