50 Olds
Old Apr 10, 2017 | 08:43 PM
64Rocket's Avatar
50 Olds
I'm starting the redo of the interior on my 50 coupe.
I'm looking for the pull straps to assist you out of the back seat.
I'm up for very good ones to just cores as to have new ones made.
and the retainers.
Also looking for the rubber tubes that connect the fresh air vent tubes in the engine compartment. Or info as to were to get a pair, or suggestions as to what you used.
Gene
Old Apr 11, 2017 | 08:47 AM
47 Convertible's Avatar
Here is where it pays to be old: That device is actually called a lap robe cord or hanger. It was developed in the very early days of automobiles when they had poor or no heat in the back seat. The cord was used to hang a lap robe from when the robe was not being used by passengers to keep warm in cold weather. I think they disappeared in about the late 50s or early 60s.
Using it as an assist to get out of the back seat could cause it to break if very much force was put on it.
You might try old car wrecking yards. There is one in Albert Lea Minnesota that seems to have some older Oldsmobiles and might have the mountings for the cord. I would think a good auto upholstery shop could make up the cord itself.
I tried a short search on ebay but found only lap robes, no car parts. Persistence pays off in searching for this stuff.
Jerry
Old Apr 11, 2017 | 06:09 PM
Tedd Thompson's Avatar
I may be mistaken but I think he is looking for the strap at head level not the robe rope mounted on the front seat backs.Could be wrong on this.... Tedd
Old Apr 11, 2017 | 07:57 PM
You are likely correct. And sometimes it doesn't pay to be old....
Jerry
Old Apr 11, 2017 | 08:08 PM
64Rocket's Avatar
Ted, you are correct.
I call it a pull strap. It screws to the "B" pillar. It is about 2 inch wide and maybe 8 or 9 inch long in the shape of a loop. From what I remember it comes to a sorta triangle shape at the top and two screws hold it to the "B" pillar with a chrome retainer.
My car is a 2 dr coupe, I'm thinking maybe a sedan also. Not to sure about a 4 dr. I say 49/50/51.
Keep your eye out, please.
Gene
Old Apr 13, 2017 | 07:36 PM
It's been to many years sense I was around the inside of a 50 Old's but on my 55 The vent pipes were made of spring wound rotted paper tubing, I replaced them with modern ( 4inch I think) plastic vent tubing from Napa. It came off the shelf and wasn't ordered special .... Tedd
Old Apr 13, 2017 | 08:16 PM
64Rocket's Avatar
Thanks Ted. I will give that a try. I will get some measurements and check it out.
Gene
Old Apr 13, 2017 | 08:40 PM
2blu442's Avatar
Gene, are you wanting the car to look original? The reason I ask is the 1978 Toronado parts car I have has pull straps to help you get out of the back seat. Maybe a newer vintage car will be easier to locate the pull straps in if you don't mind the appearance being different.
John
Old Apr 14, 2017 | 04:20 PM
Rocketowner's Avatar
I would give Ciadella Interiors a call on the pull straps ,they do make them for early Ford 2 door models. Just looked, Ciadella
Does make them for '55 Chevy 2 Dr..in material to match wind lace or will cover in vinyl, $59 a pair . Larry
File Type: jpeg
Old Apr 14, 2017 | 05:57 PM
Pull Straps
Just checked. Ciadella makes them for '55 Chevrolet 2 Dr. They will cover them to match wind lace or cover them in vinyl,your choice, for $59! Sorry ,for double posting,I checked and the image had
Apparantly not posted ,when I looked. Well I found them anyway.
Larry
File Type: jpeg
