Gas pedal removal
It should just pop off the gas pedal rod which fits into a rubber cup on the bottom of the pedal. If you need to remove the whole pedal I believe there is a pin at the bottom that can be removed and that will allow you to lift the whole thing off... Tedd
On my 54 the pedal itself just pops onto two little studs at the bottom of the pedal that have a little ball on them. The pedal is not connected to the linkage at all. It just pushes against it.
