HELP! Gas pedal removal
Old June 11th, 2009, 09:10 PM
64starfire's Avatar
I'm going to be working on the floor of the starfire and can't figure out how to remove the gas pedal. I see the threaded block on the engine side of the firewall, and can feel some sort of bolt head on the inside, but the bolt head continues to the base of the pedal. Just put a wrench to the "nut"? Does the 'extended' head of the bolt turn with it? Just really weird ya know...
thanks
64starfire is offline
Old June 12th, 2009, 02:50 AM
Yellowstatue's Avatar
Smile Pedal to the metal
There are two threaded studs with a round ball head that simply pushes into the rubber of the pedal...pull or pry up firmly to remove...if the studs are damaged then you unscrew them out of the floor...
Yellowstatue is offline
Old June 12th, 2009, 07:43 AM
64starfire's Avatar
oh yeah
This Forum + you guys= awesome
R8der4life
June 4th, 2013 06:51 PM
slowolds
July 21st, 2010 02:31 AM
Gaz Hog
June 25th, 2010 04:13 AM
My442
May 2nd, 2010 04:24 AM
jensenracing77
February 7th, 2010 05:30 AM
Quick Reply: HELP! Gas pedal removal
