Gas pedal removal
Old Jul 8, 2017 | 02:21 PM
tricordati's Avatar
Gas pedal removal
Hi. I need some guidance on how to remove the gas pedal on my 1956 88? I am installing a new master cylinder and need to pull back the carpet. Thanks
Old Jul 8, 2017 | 02:46 PM
I moved your post to its own thread, no need to hijack an irrelevant old thread. Someone should chime in and help.
Old Jul 8, 2017 | 02:54 PM
tricordati's Avatar
Old Jul 8, 2017 | 06:48 PM
Tedd Thompson's Avatar
It should just pop off the gas pedal rod which fits into a rubber cup on the bottom of the pedal. If you need to remove the whole pedal I believe there is a pin at the bottom that can be removed and that will allow you to lift the whole thing off... Tedd
Old Jul 8, 2017 | 07:30 PM
redoldsman's Avatar
Proud Viet Nam Veteran
On my 54 the pedal itself just pops onto two little studs at the bottom of the pedal that have a little ball on them. The pedal is not connected to the linkage at all. It just pushes against it.
Old Jul 10, 2017 | 08:01 AM
tricordati's Avatar
That did the trick. Thanks
beamjp
Dec 11, 2016 02:15 PM
R8der4life
Jun 4, 2013 06:51 PM
My442
May 2, 2010 04:24 AM
jensenracing77
Feb 7, 2010 05:30 AM
64starfire
Jun 12, 2009 07:43 AM
