1955 Olds brakes upgrade
Old April 7th, 2017, 03:29 PM
Performancejet's Avatar
Hello everyone. I am looking at buying the disc brake conversion from Kanter. Has anyone had experience with this set up . I have a 1955 Olds 88 that I have restored but right now the engine is out and I thought that this would be the time to do a conversion.
Performancejet is offline
Old April 7th, 2017, 06:01 PM
I moved your thread to the Vintage section. Great group of guys who can point you in the right direction.
oldcutlass is online now
Old April 7th, 2017, 08:15 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I believe there are some folks on here that have done this conversion but I am not one of them. It will require moving your master cylinder to the firewall.
redoldsman is online now
Old April 8th, 2017, 11:43 AM
55 olds brakes
Thanks redoldsman, I am not going to mount the Master on the fire wall, that's what I am concerned about.
Old April 8th, 2017, 06:54 PM
Tedd Thompson's Avatar
Olds Dad has a thread on how to change the Tredal-Vac for a modern unit that is still under the floor boards. Give it a search it was on this forum..... Tedd
Tedd Thompson is offline
Old April 8th, 2017, 11:14 PM
Ozzie's Avatar
If you ever want to do factory A/C, don't put it on the firewall; that's where the evaporator goes.
Ozzie is offline
Old April 9th, 2017, 12:29 PM
Ted, thanks for your response. Olds dad did a great jot on his article. I just don't like the pedal arrangement and might look into see if his work can be refined a bit. Jim
Old April 9th, 2017, 01:33 PM
redoldsman's Avatar
Tedd:
I had forgotten about that thread and I had a response in it..
CutLS442
Brakes/Hydraulic Systems
November 23rd, 2016 12:50 PM
Cruiser f85
July 1st, 2015 09:29 AM
garry
May 1st, 2012 04:20 PM
ben1212
April 24th, 2008 09:18 PM
72Cutlass
March 10th, 2008 07:59 AM
Quick Reply: 1955 Olds brakes upgrade
