need 46 coupe assembly help
Old Apr 29, 2017 | 11:47 PM
rennerbird's Avatar
Post need 46 coupe assembly help
I purchased a 46 coupe "project" in a thousand pieces.Body was off and frame has 69 Nova front clip, my problem is that I don't know how to assemble the front end of the car I really could use some pics of front sheet metal so I can also figure out what's missing.
Old Apr 30, 2017 | 04:44 AM
Welcome to the site, I moved your question to the Vintage Olds forum.
Old Apr 30, 2017 | 11:17 AM
47 Convertible's Avatar
Suggestions and photos
_______________________________________________
Only a thousand pieces? Should be a piece of cake Just kidding.
Mine was mostly there and I saved a few before photos that show part of the front clip. They are thumbnails below.
In addition Faxon Auto Literature has reproduced a couple of Olds manuals that should be some help. They can be purchased from Faxton or may be found on Ebay. Thumbnails below.
Post some photos of what you bought. We all like to see photos even if its a project in a thousand pieces.
There is a frame cross member that the core support attaches to. One of my photos shows this. You have to get the measurement from your firewall to the cross member and core support to even begin to be able to attach a cross member and the radiator and fender core support. Pretty much everything else aligns to those.
With your different front frame clip you will need to get that measurement from firewall to the cross member that the core support bolts to, from a factory original car and then translate that to your Nova front clip. You will likely need to fabricate that cross member.
Other parts are inner fenders, outer fenders, hood and hood hinge assembly, hood latch plate and latch assembly, piece/plate in front of and below the radiator. And there are more that I can't recall now.
Old Apr 30, 2017 | 02:05 PM
rennerbird's Avatar
Assembly help.
Thank you for the information and pics they will be a great help.I had a general idea but was pretty sure there were parts missing. ...I was right.
Old May 1, 2017 | 03:13 AM
chopolds's Avatar
Is the frame modified to accept the Olds sheet metal? I did a 69 Camaro swap on my 47 Chevy, very similar. I had to weld in a piece of tubing across the Camaro frame, to mount the stock radiator support. I also had to weld in 2 x 3's onto the bottom of the Camaro frame, to mount the bumper. Does your frame swap have there?
RTTOY
17
Nov 15, 2020 12:09 PM
stratoblues
Sep 1, 2014 06:52 AM
ffaybar
Body work
Mar 1, 2013 07:14 AM
stressed1
Ninety-Eight
40
Jan 16, 2013 05:49 PM
oils66
Nov 25, 2009 08:25 AM
