Hydramatic band adjust tools?
Old Dec 11, 2016 | 09:06 AM
kad36's Avatar
Is there anyone who will consider renting me the band adjusting tools for my '49 Olds 88 Hydramatic? I am willing to make a deposit so you will be sure to get your tools back! I want to adjust the bands in static mode...I have the tool to loosen the lock nut and tighten and loosen the band adjusters but don't have the screw in tool for the front band or the caliper style tool for the rear band...thanks for looking, Karl. kad36
Old Dec 17, 2016 | 04:22 AM
kad36's Avatar
Anyone?
Old Dec 17, 2016 | 05:57 AM
You might consider asking a privately owned trans shop in your area thats been in business for a while to see if you can borrow/rent from them.
Old Dec 17, 2016 | 06:31 AM
Rocketowner's Avatar
If you will post your need in the vintage section, you may get some response.I know I've
seen two or three members discussing what specialty tools they had for Hydramatic Band Adjustments. If no luck,there's a guy in Tennessee that sells these parts from time to time. His name is Bill Savrey (toolguy@aol.com). Best of luck, Larry
Old Dec 17, 2016 | 09:02 AM
toymobile's Avatar
Rule of thumb on external band adj is to turn clockwise until tight and back of 7 full turns, always worked for me, USE this as a suggestion.
Good luck, Johnny
Old Dec 17, 2016 | 04:12 PM
Good suggestion, I went ahead and moved the thread.
Old Dec 18, 2016 | 04:25 AM
kad36's Avatar
Band adjust
Good luck, Johnny
Hi Johnny, thanks for the tip...are you suggesting this adjustment for both bands? Thanks, Karl. (kad36)
Old Dec 20, 2016 | 12:15 PM
D. Yaros's Avatar
I would suspect the tranny in question was used in other GM makes. If that suspicion is correct, you might try posting your request with the guys on the AACA Forum?
mcc8
Jan 23, 2015 11:03 AM
gmacolton
Apr 29, 2010 12:53 PM
flatoz
Apr 16, 2009 05:06 AM
Jolly Green
Jun 27, 2008 02:21 PM
Jokers69
Aug 24, 2007 04:41 AM
