'56- Removing Heater Control Knob
Old February 26th, 2017, 02:35 PM
Frank Ignachuck
ignachuck's Avatar
'56- Removing Heater Control ****
I need to remove the heater control **** from the cable. Does it screw off or pull off? No set screw.
ignachuck is offline
Old February 26th, 2017, 05:17 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I hope you get an answer. The 54-55 are a little different but I am sure the ***** come off the same way. I replaced the controls on my 54 with ones from and the ***** are different. I never got the ***** off.
redoldsman is offline
Old February 26th, 2017, 07:58 PM
Tedd Thompson's Avatar
I think they are soldered or pressed on. I had one come off and I had a guy who worked on aircraft repaired it for me. As I remember it was a short steel sleeve( about 3/16 inch in diameter 3/4 inch long) threaded on one end with a hole in the other with a set screw or some other kind of attachment. I'm not sure what they were called but he said it was common in the aircraft industries. I know that is kinda vague but that repair has lasted 15 years so far on my 55.. Tedd
Tedd Thompson is offline
tdhill01
October 15th, 2016 03:40 AM
jensenracing77
March 19th, 2014 04:08 PM
Tedd Thompson
January 20th, 2013 04:00 PM
rlang
December 16th, 2012 10:20 AM
m455sx
January 17th, 2011 06:10 PM
Quick Reply: '56- Removing Heater Control Knob
