55 Hydramatic throttle valve lever problem
Old September 28th, 2016, 08:13 AM
Olds Scott's Avatar
While installing throttle valve rod I noticed that lever travel on transmission will not allow for proper adjustment on bell crank on engine. All carb linkages are adjusted as per manual. I had the transmission rebuilt a couple of years ago and now just getting it ready for first drive. Will I need to pull the side cover and is there an easy fix for this problem?
Olds Scott is offline
Old September 28th, 2016, 09:02 AM
Ozzie's Avatar
If someone did a rebuild on the transmission and didn't set the throttle lever correctly it might be the problem. It should be able to be cured with the side cover in place, but you'll probably need tool J-5605 or equivalent. If the rebuilder didn't have the tool and didn't take precautions before disassembly, it may have been a guess. Since you have the manual look on page 3-95 and 3-96. This part of the manual tells how to set the throttle lever. There are other tools to do it, but with no tool you also may have to "guess".
Ozzie is offline
Old September 28th, 2016, 10:56 AM
Olds Scott's Avatar
Thanks Ozzie, I have the J-5605 tool and the special tool for bending the arm for adjustment. I did that adjustment just like in the manual but the swing of the arm is still seems minimal compared to the bell crank travel up on the engine.
Old December 2nd, 2016, 07:28 AM
Olds Scott's Avatar
After some time off doing home renovations I finally got back to trying to figure out my throttle rod problem. I started the engine and warmed it up with the throttle rod disconnected and shifted it into gear with the rear wheels off the ground. With the exception of finding out that my rear wheel bearings will need replacing the trans went thru the gears smoothly up to 3rd gear, did not want to increase rpms to get to 4th with out throttle rod working smoothly. Movement of throttle rod lever did not increase so I guess pulling side cover to see if inner mechanical movement is the problem. I had the transmission rebuilt a couple of years ago so hoping this is a simple fix. Any help or hints would be appreciated.
Old December 11th, 2016, 09:58 AM
Olds Scott's Avatar
Well after watching Hydamatic Rebuild #3 on Youtube about 20 times I noticed that my throttle body plunger was not going down in the bore when actuated after I had removed the valve body from my transmission. My lever actuator was not centered on the contact pin and the upper valve had cocked in the bore. Since I had this transmission professionally rebuilt I was a little put off. Andy on the Hamb site had responded telling me about this problem so I centered the lever on the pin after resetting it in the bore and it works. Getting ready to reinstall valve body and adjust linkage. Hope this helps anyone that experiences this problem in the future
Old December 11th, 2016, 06:20 PM
cmpcpro's Avatar
Glad to hear Scott! You know the guy who made those YouTube videos is on the Facebook board. I was talking to him yesterday about my TV rod.
cmpcpro is offline
Old December 18th, 2016, 04:06 PM
Olds Scott's Avatar
Had a lot of honey-do so have not worked on the 55 in a couple of weeks. Got the side cover on the trans today and adjusted the linkage and now the kick down action is working correctly. Now have to tear down carburetor and replace accelerator pump because I believe the guy that rebuilt it for me used a pump from another 4GC.
Olds Scott
June 19th, 2015 07:59 AM
hullinger
November 9th, 2013 05:37 PM
gsnorris
July 25th, 2012 03:08 PM
stlbluesbrother
April 13th, 2011 06:52 AM
al714
November 10th, 2010 10:31 AM
Quick Reply: 55 Hydramatic throttle valve lever problem
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
