Now have the 371 out of my '57. Has anyone built a mount to put this engine on a stand. Looks like a lot of weight to have hanging on the cast bell housing end of the block. Also weight mass is so far from upright on engine stand. Looked at using front end on engine but that didn't look safe either. Would like to get it off floor to tear down. Thanks to all in advance.
I've had a 455 on a parts store engine stand for 8 years and it's just fine. I put a 394 on a similar engine stand for a few months when I disassembled it and reassembled it for an auto engines class years ago. If you're concerned just use a 2x4 between the crank pulley and the ground to support it when you're no working on it.
The bell housing mount will hold up fine as is but my China built engine stand was maxed out with the weight of the first generation engine. There was a noticeable sag at the mount and made it difficult to rotate the engine. It did work but something stouter would have been much better.... Tedd
These first generation engines weigh at least 750 lbs.
Closer to 800 with things like A/C compressors , starter , etc.
I would not use an engine stand rated at less than 1000 lbs.
The block will be fine if attached as shown below . It will be very top heavy with the heads and intake on . So be careful .
This is a 1250 # stand I got from Jeg's
X2 what Charlie Jones said. You can't be too safe. For roughly $40 more you get the 1250 lb. rating with double legs extending out. Double legs are critical for not tipping. I'd even think seriously about replacing those small diameter casters with something a bit more robust. It is not pleasant when the engine is mounted and small dia. casters get stuck in expansion joints on concrete floors, are stopped by something small like the cut off end of a 1/4 bolt that didn't get picked up etc. Tugging a loaded stand out of a joint or over a small object is just when balance is most likely to want to tip the whole thing over. Photo is typical discount tool single extended leg stand. Trouble waiting to happen.
