Removing steering box on 1949, any tips?
Old September 23rd, 2016, 07:31 AM
Dick T's Avatar
From the 14th edition of Motor's Manual:
Remove horn button and nut. Pull off the steering wheel. Disconnect the control rod at the lower end of the steering column and also the selector cable or rod. Unfasten the steering column from the instrument panel clamp. pull off pitman arm. Unbolt the gear from the frame and withdraw gear. Dick T
Dick T is offline
Old September 23rd, 2016, 06:17 PM
2blu442's Avatar
I've pulled the column & steering box from a 1954 and 55. The one thing I did differently is I kept the pitman arm on the steering box. I've got some photos I could post if that would help. John
2blu442 is offline
Old September 25th, 2016, 01:09 PM
Dick T's Avatar
Yes I'd like to see the pictures. And Thanks. What about the wiring that runs up the inside of the column?
Dick T is offline
Old September 26th, 2016, 06:15 AM
okie88's Avatar
There will be a connector above the column underneath the dash to disconnect the wires. There are also wires at the selector in the engine compartment. You will need to remove the plate at the firewall that the column goes through. The column and gear are then pulled up through the firewall. I usually leave the steering wheel on, but probably easier with it off.
okie88 is offline
Old September 26th, 2016, 07:47 AM
Dick T's Avatar
Steering Gear Removal 1949
Thanks for the tip. Looks like it might be a tight squeeze through the opening in the firewall. Dick T
Dick T is offline
Old October 1st, 2016, 12:07 PM
2blu442's Avatar
Here's some photos from a 1954. I don't know if there were any changes between these years or not, but I hope some of this helps.
I had forgotten that I removed the brake pedal and TredleVac from the car. That allowed me to remove the floor plate, which gave me a large area to remove the steering box through.
Floor panel and hole
Then this shows the rubber piece that goes into the U shaped cutout on the floor panel
Here's the piece that attaches the column to the bottom of the dash. It has four fasteners and just below it are the wires that attach to and run into the column
Then here's where the transmission rod attaches, and the place where wires connect in the engine compartment
Finally, the steering box at the end of the column
Let us know if there's any other areas you have questions about, or would like to see a photo of. John
2blu442 is offline
Old October 1st, 2016, 12:24 PM
Dick T's Avatar
Thanks for sharing the fotos. It doesn't appear as though the opening was that another plate that large is in firewall of 49's. All Hyrdramatic linkage have been removed in place is a Muncie 20. I will photograph this project for others to see what is involved.
Dick T is offline
Old August 27th, 2018, 05:19 PM
Dick T's Avatar
Well its almost two years later and tomorrow I will remove the plate covering the opening in the firewall and pray that the gearbox can make past the exhaust manifold.
Thanks to 2blu442 for the pictures and to Okie88.
Dick T is offline
Old August 28th, 2018, 12:21 PM
Dick T's Avatar
Aug 28, 2018. Update on Steering Gear Assembly Removal from 1949 Olds Coupe. This cannot be done without first removing the engine or the left fender and inner fender.
Dick T is offline
Old August 28th, 2018, 05:34 PM
coldwar's Avatar
Get it on a rack and it will slide out the bottom, box, mast jacket and steering shaft intact. Safety first - Good luck
coldwar is online now
dbuck
March 29th, 2014 11:01 AM
starfire
March 4th, 2013 04:57 PM
EightyEightCut
January 18th, 2013 09:21 AM
deaddds
June 14th, 2011 06:25 AM
Aceshigh
Drivetrain/Differentials
16
August 10th, 2010 12:56 PM
Quick Reply: Removing steering box on 1949, any tips?
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
