Crankshaft pulley removal to change front motor mount on a 324
Old Feb 24, 2018 | 01:29 PM
Gawain's Avatar
Greetings everyone, Has anyone had the crankshaft pulley off from a 54 Olds? I have two questions. Is the 3/4 nut holding on the pulley right or left hand threads? And does one need a wheel puller to get the pulley off. I have to replace the front motor mount and that crank pulley has to come off.
Thanks, Gawain
Old Feb 24, 2018 | 03:11 PM
2blu442's Avatar
I ran into something like this before. Here's the thread with a reply from one of the 1954 experts!
https://classicoldsmobile.com/forums...962-394-a.html
Old Feb 24, 2018 | 03:20 PM
2blu442's Avatar
OK, I found some pictures. The balancer and pulleys come off together. There's a keyway in the crankshaft, and once the bolt is removed you can pull or gently pry maybe tap with a mallet to remove the assembly. I'm 99% sure they were normal thread, just on there really really tight. But one of the guys who knows this vintage better than I can speak to the thread direction.
Old Feb 24, 2018 | 03:30 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have had the one on my 54 off a couple times. If you have an impact wrench it is your friend in getting the bolt loose. It is just a big right handed thread. The pulley and balancer are all made together. It comes off pretty easy. It may take a little soaking and some tapping because it has been on there so long.
Old Feb 24, 2018 | 06:26 PM
Tedd Thompson's Avatar
X2.... What they all said.... Tedd
If you don't have a impact wrench and it doesn't come off easily you can lock up the flex plate through the starter hole with a crow bar or heavy screwdriver and attack it with a breaker bar...... Tedd
Old Feb 25, 2018 | 01:48 AM
Ozzie's Avatar
You have good advice. I held the engine from turning with a turning tool on the flywheel and loosened the bolt with a 3/4" drive socket and a big breaker bar. If you can't tap the pulley off with a soft hammer you can use a gear puller; just don't pull on the ring. Upon re-installation the Olds shop manual recommends using POB number 3 sealer on the crankshaft and key/keyway to discourage oil leaking. It also recommends using a new lock washer. I don't remember doing either, and nothing leaked or came loose.
Torque to 45-50 ft-pounds.
Old Mar 12, 2018 | 11:22 AM
DFitz's Avatar
74 2.8L Capri
All good advice, and correct. I've had mine off a couple of times. Used an impact wrench. I Also had to replace the front engine mount. Be very careful on the front oil seal. Mine leaks, and I've replaced it several times, and still leaks like crazy.
Old Mar 12, 2018 | 11:40 AM
mpolds's Avatar
I have the front motor mount -- and the rear bell housing mounts for both stick and automatic, if you need them....
Feel free to call me -- Craig -- 516 - 485 - 1935 ... Long Island, New York if you can call the United States for free..... or if not, e-mail me....
1950 Model Olds
Tech Editor's Desk
Jul 20, 2011 09:02 AM
hawks70
Jun 15, 2011 11:07 AM
D Appeldorn
May 24, 2010 09:21 AM
rustycragars
Dec 3, 2009 10:46 AM
sssingo
Nov 9, 2008 03:47 PM
