1957 Super 88 key codes
Old May 30, 2017 | 07:43 PM
graysuper88's Avatar
I now have the door trim on. Loosen up the top bolts on the vent window and with a gentle pry there is enough room for the molding to drop in with out cutting out the screw countersunk area. My next job is to get keys made. I removed the trunk cly and found no numbers on it as later cars have. There is a number on the rod that turns the latch. Is this the key code? I have a ignition key but it will not work the doors. Are there numbers on the door locks before I go to the trouble to pull them out?
Thanks,
David
Old May 30, 2017 | 08:57 PM
Tedd Thompson's Avatar
You might take the glove box door off if it's not locked and take it in to a lock shop have them make a key, should be the same key but easier to take off..... Tedd
Old May 31, 2017 | 06:28 AM
Thanks,
David
There SHOULD be numbers on the door lock cylinders, but there SHOULD have been one on the trunk lock as well. Possibly those cylinders have been replaced, thus no code.
I'm not sure what you are trying to do, but I can punch new keys from the code and also recode the door locks to match your ignition key. If you have the trunk lock cylinder out, it is also very easy to read the tumblers and make a new key from that. PM me if interested.
Old Jun 3, 2017 | 08:13 PM
The trunk lock key code is on the rod that turns the latch . Took a gamble and it worked. The door lock codes are stamped on the plunger that hits the latch arm and can be read by holding the button in. Numbers where on top of the plunger. Looked at a handle off Holiday parts car I have and the code was on the bottom requiring you the remove handle to read. All easy enough. Thanks
Rustbucket2
Apr 23, 2016 12:06 PM
CreepyOldGuy
Jan 19, 2015 04:48 AM
valmaye
Feb 19, 2012 10:41 AM
86ChebbyWagon307
Jul 5, 2011 07:09 PM
