what wheels
Sure. So long as they have the 5 x 5" bolt circle.
Perhaps you can tell us WHICH "Chevy" wheels...
If you are referring to the 5 x 4.75" bolt circle used on pretty much every Chevy from the 1960s to 1970, no.
If you are talking about the wheels used on the Impala and Caprice from 1971-76, yes. If you are talking about the wheels used on the 1977-1996 full size cars with HD brakes, yes. If you are talking about the wheels used on some half-ton pickups and Astro vans, yes.
SUBURBAN 1/2 TON 2X4 71-91 15×6(7) 5×127 1/2-RH
TRUCKS 1/2 TON ALL MODELS 2X4 67-87 15×6(7) 5×127 1/2-RH
BLAZER/ JIMMY
FULL SIZE 1/2 TON 2X4 71-91 15×6(7) 5×127 1/2-RH
There are a lot of used 15" but good luck finding any with good bolt holes, most I found were worn bad. I bought new ones from Summit, the originals on my 55 were 6" wide but I could only find 7" wide, Summit told me the 6" wide are only made for trailers. The 7" work fine and are the correct size for 225 tires
Just make sure the backspace is 4 or 3.5", my original wheels were on the center of the wheel or 3" backspace.
I think Speedway Motors is having a sale.........
http://www.summitracing.com/parts/crr-3975750
BLAZER/ JIMMY
I've got eight 15 x 7, 5x5" wheels from the two B-body wagons that I'm parting. Lug holes are perfectly fine. I also recently sold four aluminum wheels from one of those half ton trucks, also perfect. Personally I can't see spending $80 or more for one wheel when I can get four for that price.
In the mid to late '80's the Astro van had an optional Aluminum wheel that I always thought would look very nice on a '55 Olds. If you like them,maybe there's a set still around somewhere. Good luck,Larry
