what wheels
Old Apr 3, 2016 | 06:31 PM
fatback's Avatar
what wheels
Will Chevy wheels fit 55 Olds?
Old Apr 3, 2016 | 09:00 PM
Ozzie's Avatar
No. The bolt circle is 5" on the Olds and 4-3/4" on the Chevy. Pontiac should fit through '60 on the 5-1/2" wide wheels.
Old Apr 3, 2016 | 11:43 PM
svnt442's Avatar
Some B body wheels will fit as well as 5 lug truck rims as those should be 5 x 5" as well.
Old Apr 4, 2016 | 06:32 AM
Tedd Thompson's Avatar
And Buick of that era but they will be a little wider but still work... Tedd
Old Apr 4, 2016 | 07:16 AM
Sure. So long as they have the 5 x 5" bolt circle.
Perhaps you can tell us WHICH "Chevy" wheels...
If you are referring to the 5 x 4.75" bolt circle used on pretty much every Chevy from the 1960s to 1970, no.
If you are talking about the wheels used on the Impala and Caprice from 1971-76, yes. If you are talking about the wheels used on the 1977-1996 full size cars with HD brakes, yes. If you are talking about the wheels used on some half-ton pickups and Astro vans, yes.
Old Apr 4, 2016 | 08:11 AM
blento's Avatar
Brent in Georgia
SUBURBAN 1/2 TON 2X4 71-91 15×6(7) 5×127 1/2-RH
TRUCKS 1/2 TON ALL MODELS 2X4 67-87 15×6(7) 5×127 1/2-RH
BLAZER/ JIMMY
FULL SIZE 1/2 TON 2X4 71-91 15×6(7) 5×127 1/2-RH
There are a lot of used 15" but good luck finding any with good bolt holes, most I found were worn bad. I bought new ones from Summit, the originals on my 55 were 6" wide but I could only find 7" wide, Summit told me the 6" wide are only made for trailers. The 7" work fine and are the correct size for 225 tires
Just make sure the backspace is 4 or 3.5", my original wheels were on the center of the wheel or 3" backspace.
I think Speedway Motors is having a sale.........
http://www.summitracing.com/parts/crr-3975750
Old Apr 4, 2016 | 08:19 AM
You must be looking for love in all the wrong places...
I've got eight 15 x 7, 5x5" wheels from the two B-body wagons that I'm parting. Lug holes are perfectly fine. I also recently sold four aluminum wheels from one of those half ton trucks, also perfect. Personally I can't see spending $80 or more for one wheel when I can get four for that price.
Old Apr 4, 2016 | 06:23 PM
Rocketowner's Avatar
Smile
In the mid to late '80's the Astro van had an optional Aluminum wheel that I always thought would look very nice on a '55 Olds. If you like them,maybe there's a set still around somewhere. Good luck,Larry
Old Apr 10, 2016 | 09:18 AM
gonepaddling's Avatar
The Astro van and Safari had 5x5. I have Safari regular steel rims on my 47. Chevy pickups C-10 had them also.
Old Apr 10, 2016 | 06:00 PM
fatback's Avatar
Thanks for the info fellers
My442
Dec 26, 2017 05:08 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
jdorour
Drivetrain/Differentials
Dec 16, 2006 06:41 AM
biguke2001
Sep 23, 2002 07:54 PM
