- Hydra Matic Fluid
- 303 hot start issues
- 57 Olds hood insulation question.
- 1957 88 2 door hardtop vin info
- 1957 Olds Super 88 sedan vent window issue
- 1948 Futuramic 98 fender welting
- Bucking after getting up to speed.
- 1959 98 parts interchange 2 door vs 4 door
- 1955 Rochester 4 Jet float specs.
- 55 olds front axle backing plate gasket
- 1957 Oldsmobile Fiesta Hood Adjustment..
- '55 Ignition system?
- 1950 pinion seal
- 57 door hinge pins?
- 6 volt ignition question
- Brake fluid level?
- 1948 / 49 Radiator Help
- 1955 Olds 98, Bendix or Moraine Power Booster?
- 1954 Olds 88 Sill plates
- 41 Olds steering wheel - What would you do next for hairline cracks?
- new wheels/tires exhaust
- Potmetal Diecast Grille Restoration - 1935 Olds
- Super 88 parts supply
- 55' Olds power/manual steering gear
- Cowl tag
- Cowl tag
- Throttle Return Spring Help - 48-49
- Big Six parts
- 1941 Olds - Parts needed.
- 57 Olds 98 window glass ID
- Stopping wind noise
- Is there a sealer between dash and cowl?
- Need help keying out 1959 transmission
- 1956 Oldsmobile rocket 88 oil fuel and vacuum lines help!
- 41 dash removal
- New member - engine/trans identification needed
- 1950 trim plate and VIN decode
- Light switch removal 1941 - Help please
- 1950 Olds fuel pump issues
- 1957 suspension question
- 1949 Oldsmobile rear-end and brake system questions
- Looking for kit to restore steering box Oldsmobile 1948
- '55 Glass bowl fuel pump 324
- Need help identifying 1954-55 water pump pulley
- Coolant leak 1949 Olds 88
- 1947 Olds Convertible
- 1917 Oldsmobile model 45 V8 engine specs
- Vacuum lines in 1956 Oldsmobile Super 88
- 1958 and 1959 Super 88 and 98 Illustrations
- Olds suspension
- Restauración Oldsmobile 1954
- Question about bat winged air cleaners
- 1950 Olds with 1955 Olds transmission
- New 1956 oldsmobile 88 owner help!
- Classic Oldmobiles Illustrations >> Soon on T-Shirts
- Is the 1959 98 Longer than the super 88
- 10,608 mile two owner 56 Super 88, the Story
- 1955 Super 88 4DR Sedan Seat Covers Needed
- Question about power bench seat in 1955 Olds 98
- Project Low Buck (?) 1955 88
- Underhood insulation
- Help with 1957 Olds Supper 88 Front Wheel Bearing Installation
- 1958 Oldsmobile complete rear end swap into 1955
- 51-52 Front Bumper NOS Not Mine
- How to confirm original color on 56 88?
- F35 / F36 timing
- Parts Interchange
- 1956 Olds front sheet metal assembly.
- 1949 Olds 88 transmission rebuild
- 1954 Power Steering pump interchange question
- Olds 303 Value?
- 49 98 convertible
- 1955 Super 88 4dr Dash Pad Removal
- Door trim fabricated with 3 D printing
- 1955 Super 88 Fuel Tank
- ‘55 2DR Hardtop Resto Need Help identifying missing heater ductwork
- Olds 324 Oil Pan Gasket Install Question
- How to open hood 1948 "98"
- 3D printed door trim
- 1955 olds super 88 axle oil drain
- 55 Hydramatic Question
- 1955 Super 88 4dr Rear Drivers Door Not Opening
- Piston
- Oil filler cap decal 35-50 Olds
- Delco wheel cylinders
- Front shocks
- Disc brakes
- 1948 Radio
- Timing a 1949
- Measurements of antenna location in 41
- 1954 Olds Walmart battery
- Is the dashboard welded or bolted in?
- Best grease for knee joints and tie rod ends 1950 98
- 1949 Olds 88 tire jack pics
- A happy update
- AT-205 Re-Seal?
- FUEL PUMP on 1948 series 98
- 1953 88 Universal Joint
- Early rocket identification
- 1935 Oldsmobile parts
- 1954 glass fuel bowl removal
- Choke flap does not close by itself on Rochester 4jet 1956
- 1955 '98 front suspension
- Speedo recalibration
- 1953 Olds Super 88 new home
- Service manuals
- Removing chrome trim on 55 dash
- USA Auto
- 1935 Oldsmobile doors
- 1955 olds super 88 non AC water pump
- What size wheel have i got
- Parts needed
- 1948 Help
- J2r adjustable rocker arm ID
- Oldsmobile Truck
- Electric Fuel Pump for a '56 Super 88
- 1956 Shift selector adjustment
- No brake or tail lights - 1948
- 1948 Trans question
- Simply Gorgeous
- 1958 Olds Water Pump
- 1948 Oil Pan Gasket
- 1949 Olds 88 hood adjustment
- 1948 Tire Size
- Rebuilt Rochester Quadrajet wont fire up Super 88 1956
- '56 Olds 98 2 dr. hardtop
- 57 Olds Convertible Top
- Shock Absorber Oil
- 57 olds Engine heat question
- Help me identify the year/model of this Olds?
- '55 Oldsmobile Steering/Handling
- 1956;Olds Manual
- 1957 J2 center carb vacuum switch setting help
- Early 4 cylinder engine
- This '55 had an unexpected second life...
- 1956 Olds Starter
- 1956 Intake Manifold Hot Air Tube
- 1957 Oil Funnel
- Upholsterer in Southeast for 56 Starfire
- 1955 olds 324 connecting rod size
- From France
- 1949 Olds 88 tire size
- 1956 rocker moldings
- Correct hub caps?
- Thermostat gasket
- When it all goes right!
- Timing creeping out of spec
- ignition lock cylinder 1949 Olds 88
- Dropping the Tank on a '38.
- 1949 Olds 88 distributor
- Brake Booster
- Sway Bar Bushings
- 41 distributor adjustment
- Wheel Cylinder Replacement
- 41 ignition locking coil removal
- What else can be done to fix this 1941 Speedometer?
- 41 straight 8 loses power with acceleration
- 1953 Parking light housing
- 1950 Oldsmobile - Oil filter adapter OFA-1 detailed instructions
- Faults/defects - 1949 rocket 88
- 1950 Oldsmobile 88 - Spark plug recommendation
- 58 olds 98 script
- '55 rear vent window glass replacement
- 1957 Turn Signal Indicator Light Circuit
- 55 old turnsignal
- Questions about Brake Parts on a 1955 Olds 88
- Oldsmobile 61 dynamic 88
- Will 1949 98 skirts work for 1950 98?
- new distributor olds 303?
- 1938 Olds Straight 6 Inheritance -
- Restoring !ate Grandparents 1958 Oldsmobile 98 4 door sedan
- 1949 0lds rack and pinion
- Exhaust bolts leaking coolant
- 1960 convertible
- 1949 Olds 88 starter rebuild
- 55 Super 88 speedometer jumps randomly
- 1949 Olds 88 speedometer
- '50 Super 88 Oil Filter Drain Location
- Trouble at temperature
- 48 Olds Air Cleaner Color
- 1957 Oldsmobile transmission question
- Window issue
- Replacement of Weatherstripping on doors of 1950 98 4dr
- 1949 Olds 88 steering gear removal
- 1950 olds 98 transmission issue changing gear and reving sound 10-20 mph
- Are these 394 Heads?
- 1955 Olds Super 88 Trans Leak
- 1954 olds super 88 convertible
- Rim replacement
- Need help identifying hood lip trim, 1954 and 55?
- Brake springs
- Clock wiring
- 1957 Olmobile Speedometer
- Filter in early Hydramatic transmission
- Drum brake is stuck
- how about 54 324 tips?
- 3 on the floor
- vacuum wiper blues
- Best/correct clock?
- Help identifying an Oldsmobile inline 6
- What type of differential do I have?
- Value?
- Gas tank door spring
- Help Me Learn About This Car
- 48 Olds steering box outer tube removal
- Good latch cable
- Does anyone recognize this Olds hood emblem?
- Who has new leaf and coil springs?
- Help to remove oil pan of 41
- Is this an original Air Cleaner?
- Numbers on the block of 41
- 1936 Oldsmobile Street Rod
- 1949 Olds 303 external water bypass
- Here she is!!! 1938 Olds L38!!
- 1938 L38 Question
- 303 oil pan gasket install
- 48 olds steering update
- Batwing air cleaner?
- 1930 Oldsmobile Water Pump
- 303 assembly
- 1957 oldsmobile radiator
- 1957 olds water valve control
- Removing tool for 1955 bezel ignition
- Hagerty Aricle Fiflty's Oldsmobile
- 59 rocket fuel pump question
- 1957 spark plugs
- 55 olds 98 passenger side air box removal
- Harmonic balancer removal
- 49 Olds 88 trunk switch?
- Marking its territory
- 1955 324 heads vs 1954 heads
- A bit of shimmy
- convertible switch modification
- Clock working?
- Jacking point?
- 1957 98 exhaust manifolds
- 54-55 Olds Rocket 185HP 5ft Dealer Banner
- Lifting body off frame 1955 olds
- Tell me about your exhaust
- Air Cleaner from 49 Oldsmobile 76
- Running Engine and Exhaust, thoughts?
- Bat Wing air cleaner?
- Filling Up - Questions About Fuel
- harsh hydra-matic down shift
- 1957 door sill question
- electric fuel pump
- 55 Olds Wiring
- 324 lifter noise
- fixing accelerator hesitation
- 1947 oldsmobile nova clips any pics
