Brake master cylinder access - 1957
Old Dec 14, 2013 | 05:27 PM
john116's Avatar
Hi,
I just took delivery of a 1957 Oldsmobile 98 with air conditioning and power brakes. It safely made it from Texas to Sydney (Australia).
I have a question - how do you gain access to top up/bleed the brakes? I have a service manual that tells me how to remove the power booster, etc, but I can't see how, when it's in the car, you get access to it to check the level, etc. The air conditioner evaporator box is sitting right above it, which seemingly blocks all access.
Thanks in advance for any suggestions. As is normal with a 'new' car, just finding my way round it.
John
Old Dec 14, 2013 | 06:00 PM
Mark57's Avatar
Hello John;
Mine doesn't have AC, but there is a dip stick between the steering column and the wheel well that you top the fluid up through.
Mark
Old Dec 14, 2013 | 11:38 PM
john116's Avatar
So yes, can see the dip stick top, but can't reach it from the engine bay due to the large air conditioner evaporator sitting above it.
Old Dec 15, 2013 | 07:34 AM
Mark57's Avatar
Do you have a picture of this? As I mentioned mine doesn't have AC so I cant really comment any further. I can get to mine from underneath but its not very easy.
Old Dec 15, 2013 | 09:08 AM
citcapp's Avatar
I do not have AC in my 57 either. Its tight even without the AC. You may have to unbolt the evaporator and move it as much as the cooling lines will allow to access the master cylinder.
Old Dec 15, 2013 | 11:56 AM
john116's Avatar
Pictures of engine bay below. They didn't make access to the master cylinder easy!
http://www.stkarchive.info/olds1.jpg
http://www.stkarchive.info/olds2.jpg
http://www.stkarchive.info/olds3.jpg
Old Dec 15, 2013 | 01:42 PM
Mark57's Avatar
[QUOTE=john116;628411]Pictures of engine bay below. They didn't make access to the master cylinder easy!
I see what you mean!! Very crowded under there, looks like todays cars....almost. I'm thinking you will have to get at it from underneath.
Beautiful clean engine bay. How long have you had it?
Mark
Old Dec 15, 2013 | 02:12 PM
citcapp's Avatar
Yikes, that is tight might try a light underneath then use a mirror with a handle to see what your working on. Then standing on a stool maybe you can reach down to get to it. Best if luck with that beast
Old Dec 15, 2013 | 02:35 PM
redoldsman's Avatar
Proud Viet Nam Veteran
That is almost as bad as a tri-five Chevy with factory air. You can't even see the valve cover on the right side of the engine. I think often times little thought was given to maintenance. Your engine bay is beautiful. A J-2 with factory air. WOW. This one had a big price tag for the day.
Old Dec 15, 2013 | 06:08 PM
john116's Avatar
Oldsmobile
I've had it 3 days. I picked it up from the warehouse in Sydney on Friday afternoon.
It took about 10 weeks total time to get from Texas (Dallas) to Sydney. Only about 3 weeks of that was actual 'on the ship' time from Longbeach to Sydney.
Old Dec 17, 2013 | 04:31 PM
Mark57's Avatar
Can you post a few other pictures of her. If the rest is as nice as the engine it looks like a great find.
Mark
Old Dec 18, 2013 | 02:09 AM
john116's Avatar
1957 Oldsmobile
I haven't taken any pictures yet. The ones in the location below were the dealer ones taken before it shipped to Sydney.
The car is not in perfect condition, but it's not too bad for it's 56 years.
http://www.stkarchive.info/1957_Oldsmobile
Old Dec 18, 2013 | 02:45 PM
Mark57's Avatar
Very nice, looks almost identical interior to mine. Your dash is in better shape. Have a good time with that! Mines parked for the winter now.
Mark
Old Dec 19, 2013 | 11:22 AM
john116's Avatar
no snow
Doesn't ever snow in Sydney, so can use it all year round! :-)
Old Dec 19, 2013 | 04:06 PM
Mark57's Avatar
YAYAYA.....at least we have an excuse to work on them....I hate working on it when I can be driving it
Mark
Old Dec 19, 2013 | 04:42 PM
Tedd Thompson's Avatar
Just wondering could a person using a hole saw open up say a 3 inch hole under the floorboard carpet and service the master cylinder from that area...Just a thought ...Tedd
Old Dec 20, 2013 | 02:32 PM
redoldsman's Avatar
I don't think that would work since it pretty much has to be serviced from under the hood. I get my rebuilt treadle vac back next week. I dread bleeding the brakes. I hate working on brakes. I will let you guys know how it works. For what I spent, it should be good.
Old Dec 20, 2013 | 03:22 PM
I did that on a 53 Chevy we swapped in a v8 and it made for much easier access. I made the hole big enough to remove the whole M/C and fabricated bracket as a unit. Made an 8 inch hinged and glued the carpet to it.
mbat
Brakes/Hydraulic Systems
Apr 12, 2021 07:40 AM
kens69olds
Jun 25, 2014 07:35 AM
aliensatemybuick
May 25, 2010 10:02 AM
<marksz71>
Oct 20, 2006 07:14 PM
