How to bar over a motor?
I picked up a 37 Olds inline 6 that was rebuilt but sitting approx 10 yrs. The front pulley does not have a nut with which to put a socket on to bar over. It has what looks like a nut where you would have cranked the car from there to start it like the OLD cars did. Since I dont have a crank tool and even if I did, there is no way to hold it against it to turn, any other ideas to safely work the motor? It has a starter/ gen mounted but no coil at this time. Thanks Pat
Take the starter off and turn it using a lever on the flywheel ring gear.
Before you start take the plugs out and put your favourite easing oil down the bores, preferably leaving it for a day or so before you try turning the engine over.
Roger.
Roger.
You might give it a bump with the starter to see if it is infarct seized, that is after removal of plugs and following the advise from above about oil in the cylinders. I have also unstuck a not so badly stuck engine by rocking it back and forth on a concrete serface....May the force be with you....Tedd
"your favourite easing oil "
Gotta love the British language. That's a great term.
As I reread this post of deadds I believe he is working with only a engine long block(not a whole car), if this is the case one can still use the starter to turn the motor over but rocking it back and forth on the concrete, not so much....Tedd
Would "penetrating oil" be a better term?.
If lifting a wheel and turning the engine over doesn't work it probably needs attention that requires removing it anyway. Is it a flathead or ohv in a car of that vintage?. I ask because the bores might be free but the valves could be stuck in the guides, if it's a flathead then the engine needs removing, if an ohv just the head needs to come off.
Roger.
Roger.
Roger.
Roger.
I was aware of the car age but generally when you get an old non running car the battery is toast especially a old 6 volt, a handy 12 volt will let you know if you have other problems, please jump it directly to the starter not through the system....Tedd
Wings 'em right over as long as you don't have to crank for long.
I don't know whether it's "kosher," but some guys used to convert to 12 volts and keep the 6 volt starter, because it did work.
As for the easing oil of my choice( I gotta giggle as I typed this) I use a 50/50 mixture of acetone and automotive transmission fluid .
Eric, ya we did that for a lot of VW's that were around back then, change the generator/ regulator and few bulbs and the car was now a 12 volter.
Better yet on old Chevy trucks you could put a 8 volt battery, bump up the regulator so it put out 8 volts and not change anything else, bright headlights and the heater blower really worked for a change...Tedd
ATF is used to aid friction in a trans, not as a lubricant. it is also very thick and does not penetrate as well as mystery oil, or bolt breaker.
fill the cylinders with mystery oil, let them sit overnight, hit it with bolt breaker, let it sit for a few mins, then try to crank the motor.
I started a '68 caddy 472 that had sat for a decade and a half with this method, and with a little persuasion (2 twelve-volt batteries daisy-chained together) we got it to crank.
I know an OHV big block is far from a flathead I6, but the same principals apply.
make sure it has oil in it, and prime the oil system if you can.
sounds like you shouldn't have any problems though. good luck
All well and good, but if you are going to argue you need to cite your sources.
The ATF / Acetone idea comes from an April-May 2007 article entitles "Testing Different Types of Penetrating Oils," in Machinist's Workshop magazine (Volume 20, #2) by Lloyd W. Bender, in which he tested a number of commercial penetrating oils, including PB Blaster and KROIL, in a controlled setting, and found the ATF / Acetone mix to be the best. He used ATF and Acetone because it was the closest he could get to Trichloroethene and ATF, which was an old standby before TCE was banned.
The fact is the ATF / Acetone works and works well, regardless of your teleologic rationalizations about why it should not.
Last edited by MDchanic; April 12th, 2013 at 09:02 PM. Reason: ethene, not ethylene
The ATF / Acetone idea comes from a 2010 article in Home Shop Machinist magazine by Lloyd W. Bender, in which he tested a number of commercial penetrating oils, including PB Blaster and KROIL, in a controlled setting, and found the ATF / Acetone mix to be the best. He used ATF and Acetone because it was the closest he could get to Trichloroethylene and ATF, which was an old standby before TCE was banned.
I learned this from this old dude that ran a salvage yard and I never questioned his logic because it made sense.
that being said, I know as a fact that marvel/penetrating oil combo works wonders on an engine that has sat for 10-15 years.
good luck OP!
Dealing with this issue now,although not an olds motor,it was a running motor that was parked 30 years ago in a barn and last fall tried to turn it over-no go. Always the assumption the pistons stuck-took head off and poured various liquids-diesel-lacquer thinner -gas stabilizer -acetone- brake fluid- after a few weeks the cylinders leaked the fluids out but the point of my story is that I removed the pistons and motor still frozen,pulled bearing caps and ample rust on the crank journals. They can rust too-thankfully I didn't free up motor to grind up this mess! Btw,2 cylinders did not leak down and assumed the pistons seized but came out super easy and motor was not piston seized in my opinion.
Success. The plugs were only finger tight so put 2 bottle caps of marvel in each hole. Pulled the pan plug and I think it was only prelube that had settled to the bottom. Put in 5 qts as per the manual and raised one side. Took a little coaxing but the fan blade turned. New ? is in 3 rd gear, I get 3 full rotations with a 16 inch tire to fully cycle the engine pulley. Isn't there a way to figure out what gearing I have in this without pulling the rear end?
Third gear is usually 1:1, and an open rear with only one wheel turning will turn twice as fast as when both wheels are turning, so that would imply a 1.5:1 rear end ratio, which seems a bit steep.
I'd try putting it in neutral, raising both wheels, and turning the driveshaft to confirm the rear-end ratio.
For increased accuracy, turn it ten times, then divide the answer by ten.
Using this math for dummies, I would be turning the tire again and watching a mark on the shaft right? Whether this makes a differance or not, I raised one side at a time and was able to turn the motor from both sides. I originally counted 1.5 wheel turns to get the belt one rotation but X2 it thinking one rotation would only be 2 of the 4 strokes internally. Is this backwards *** thinking?
You need to be measuring how many times the crankshaft pulley rotates, unless the fan pulley is exactly the same diameter as the crank pulley you will get misleading information.
It's the number of turns the engine makes that will determine the rear end ratio, the fact it's a 4 stroke engine makes no difference.
Roger.
Roger.
#32
So with ONE wheel turning, and the other wheel stationary, the driveshaft turned 1.825 times?
With the driveshaft turning only one wheel, that wheel turns twice as fast, so when you do it the other way around, with only one wheel turning the driveshaft, the driveshaft turns twice as slow (or half as fast ).
That means you need to multiply the driveshaft rotations by 2, so 1.825 x 2 = 3.65, so you have a 3.65:1 rear.
To check yourself, jack up both wheels and rotate the driveshaft with both wheels turning - the driveshaft should turn 3.65 times for 1 rotation of the wheels (or 36½ times for 10 rotations of the wheels).
#33
Yes. While both wheels were off the ground, I turned the driver side to turn the shaft. The other wheel did not spin while doing this that I saw. That ratio seems reasonable for that year. I'll look it up in my manual to see how close it is to a factory pumpkin. My God, I barely remember to brush my teeth let alone keep math equations straight!
BLACKCADDY
June 2nd, 2015 09:38 AM
65442ragtop
May 21st, 2014 10:31 AM
