1956. 88 engine and transmission removal
Old Oct 7, 2013 | 11:55 AM
bauerterry's Avatar
Any help would be nice...
I want to remove engine and transmission in one unit if possible this winter for seals and gasket replacement. The 56 shop manual does not address this and was wondering if anyone has done this and has any suggestions, the car is totally stock with dual exhaust.....
Any help and suggestions would be appreciated......thanks
Old Oct 7, 2013 | 08:48 PM
55/98's Avatar
Probably easyier to remove the front clip for access to everthing.
Old Oct 7, 2013 | 09:03 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I haven't done one but from what I have read on here, it is better to separate them. That transmission is cast iron and very heavy. If you do it you better have a two ton hoist.
Old Oct 7, 2013 | 10:22 PM
59-59-59's Avatar
That combo is unbelievably heavy. I would separate the two - the angle you need to tilt the engine and transmission to clear the front bumper is scary
Old Oct 8, 2013 | 05:39 AM
Olds Dad's Avatar
Collector of Stray 55's
IMHO, don't separate them.
Yes, it's a heavy assembly, but the rear engine mounts are actually integral with the transmission - if you remove the transmission, you'll remove the rear mounts and will have to support the engine.
I've pulled a couple with a regular old fasioned cherry picker - just make sure you have the chains secured good to intake or head bolts with a thick washer.
As previously stated, removing the front clip will make it easier - at least the radiator and the surrounding sheet metal.
As a tip, take the weight off of the motor while removing the rear mounts.
Old Oct 8, 2013 | 12:22 PM
Tedd Thompson's Avatar
I agree with Olds Dad and I also have removed a few and found it much easier to pull the engine and transmission together. If you do separate the engine and transmission the car is stuck where it is unless your transmission jack is movable .
Remember there are about 28 1/4 inch bolts holding the flywheel( flexplate) on and they are much easier to access out of the car.
I've never taken much more than the radiator and it's supports off the body ( I left the clip alone) and had plenty of room to lift the engine forward and out but I can see where it could be helpful and if you are going to clean it up later you might as well.
Here is a poor quality shot the only one I have of my dad and I pulling a engine but you can see sort of what still on the car....Tedd
Old Oct 9, 2013 | 08:49 AM
Olds Scott's Avatar
Used a 2 ton cherry picker and a transmission adapter tool for my floor jack. Removed the front tin except fenders for access and repaint before reinstallation. Using both tools also made for easier separation of the trans and engine.
Old Oct 9, 2013 | 09:15 AM
I have lifted most of my engines out with the hydraulic bucket off a tractor, works great for me and no worries about weight but I had access to all kinds of farm equipment at my dad's place.
JackJack56Olds
Mar 16, 2015 07:51 AM
monte56
Feb 27, 2015 03:01 AM
golds56
Aug 1, 2012 04:04 PM
oldolds51
Drivetrain/Differentials
May 2, 2010 11:23 AM
phill_ratrodv8
Feb 25, 2008 02:31 PM
