47 Trunk Lock Info Wanted
Old Oct 4, 2010 | 09:03 AM
47 Convertible's Avatar
My 47 convertible, 60 series, came to me with just a bare trunk, hinges and the arm that locks it in the open position. I am trying to gather all the stuff I need for the rest of it like the emblem, handle, lic. plate holder/light and the locking mechanism inside the lid.
I really need some pics of outside and inside so I can identify what is missing and any leads to those parts. I have found the emblems and a handle or two on ebay but don't want to bid unless I know I am getting the correct stuff. I have not seen the inside locking mechanism anywhere yet. It seems like 45-47-48 parts are pretty interchangable in some models/years. Is it the same with trunk parts?
I'm hoping members with these models can set me in the right direction. Thanks for any help.
Jerry
Old Oct 4, 2010 | 10:03 AM
citcapp's Avatar
Here is what I have out of the 1948 Master body parts manual
Old Oct 4, 2010 | 11:31 AM
Thanks very much for the drawings. Looks like I am needing a whole lot of stuff. Where is a parts 47 when you need one?
Old Oct 4, 2010 | 01:00 PM
Oldsguy's Avatar
Past Administrator
I will try to take a photo of the mechanism on my '46 for you. Interestingly, it has no hinge or spring assembly.
Old Oct 4, 2010 | 01:32 PM
Thanks Oldsguy. Much appreciated.
Old Oct 4, 2010 | 05:21 PM
Oldsguy's Avatar
Past Administrator
Here they are. A few may not be too focused. I sure hope this helps.
Old Oct 4, 2010 | 05:22 PM
Oldsguy's Avatar
Past Administrator
and here are some more.
Old Oct 4, 2010 | 05:26 PM
Oldsguy's Avatar
Past Administrator
When you twist the handle on the outside is causes the latch mechanism to swing back and up (against the lock plate which I didn't photograph). Does this make sense?
Old Oct 4, 2010 | 11:03 PM
Dan, makes perfect sense. Ingenious mechanism. Now I have to find an operating one and a handle and a latch plate. Do you know if the other type handle operates the same internal mechanism?
Thanks very much.
Jerry
Old Nov 8, 2010 | 09:27 AM
The follow up to this thread is that I located and bought a handle and lock which turned out to be from a 47 4dr. Doesn't come close to fitting the holes in the 47 convertible trunk lid. There must be different handles/locks for different models. I know there are the 90 degree shaped handles and the 'T' shaped handles. The only pic I have of a 46-48 convertible shows it with the 90 degree handle (handle is 90 degrees to the shaft that goes into the lock). In addition the rubber piece that came with the handle I bought is imprinted "47 4 dr." which further suggests there were different handles for different models even among the 90 degree shaped handles. Anyone with more information on the handle variations by model and body style could sure help out. Thanks,
Jerry
Old Nov 8, 2010 | 11:30 AM
Oldsguy's Avatar
Past Administrator
Jerry,
Sorry I missed your request for a follow-up. I forgot to subscribe to this thread to give me a reminder, so I forgot. I have bad memory. I am not surprised about the different configurations. Looking at the FSM that I have it shows different handles too. I hope you can get the problem worked out though.
Old Nov 8, 2010 | 12:46 PM
Thanks for the further information Dan.
FSM??? I guess I am not up on my Olds vocabulary. Please explain and if it shows which handles and locks go with which model and series, could you send the information pertinent to the 47 Convertible Model 66.
Finally, I was going to put a pic of the rubber piece on my post this a.m. but couldn't figure it out as I kept getting asked for the http:// where the picture was. The pic is in my puter in the 'My Pictures' program. Any help there appreciated too.
Jerry
Old Nov 8, 2010 | 05:00 PM
citcapp's Avatar
See my earlier pots; After further research the top unit in this picture was also used thru 1948
Old Nov 8, 2010 | 05:27 PM
Thanks Pat and Dan. I will continue looking for the 90 degree handle and related outside trim that sits at the proper angle for the convertible trunk lid which has less of a slope than the 4dr. So many parts to find, So few 40s Oldsmobiles out there...
Old Nov 8, 2010 | 05:58 PM
Oldsguy's Avatar
Past Administrator
To upload a picture you should use the advanced option and from there you will find four (or five) empty slots for file locations with a button to the right of each which is marked 'browse'. Click on that button and you will be able to browse to your picture location (similar to using windows explorer). After selection of the picture you should click on the 'upload' button. Be sure to take note of file size limitations. Good luck.
goldie442
Aug 21, 2015 11:01 AM
Deltarocket
Mar 20, 2013 09:38 AM
Lady72nRob71
Jan 14, 2011 06:06 AM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
1973olds98
Jul 22, 2009 06:08 PM
