Updated driveline for '47 Olds
Old Jun 1, 2010 | 04:53 PM
D.Mac's Avatar
This weekend I set the engine and trans, 455/th400, into the engine bay to start figuring out mounts etc. in my '47 model 76. Couple of problems cropped up right away. First, my trans has the short output shaft/housing, and it looks like the U-joint would be too far forward and the driveshaft would move too far up and down where it passes through the X member. Appears the "medium" length housing/shaft will correct this problem. Also, I was using a later "stepped" GM driveshaft for mock-up, and the diameter is definately too big for the opening in the X member. I know there are several others on this forum that are, or have done similar swaps, and I was looking for comments or tips on these issues.
Thanks, Doug.
Old Jun 1, 2010 | 04:57 PM
Red Delta's Avatar
Registered Abuser
This sounds like an awesome project. You should post some pics.
Old Jun 1, 2010 | 07:52 PM
Erinyes's Avatar
Want me to crawl under my '53 88 and take some pictures? 425/TH400. I have no idea how the frame sizes match up between the two, but it might help...
Old Jun 2, 2010 | 06:06 AM
Pat and Oldsguy have post WW2 40s Oldsmobiles with 455/TH400s. I recall that Oldsguy had to have the driveshaft modified quite a bit to fit the TH400.
Old Jun 2, 2010 | 06:09 AM
Oldsguy's Avatar
Past Administrator
My '46 has a long tail shaft TH400 and it fits. Maybe I can find a few photos or make some and post them. I had the driveshaft modified so it would fit the transmission on the front and the original 3rd member in the rear. I have a 9 inch on the garage floor that will go in someday......
Old Jun 2, 2010 | 06:27 AM
Oldsguy's Avatar
Past Administrator
Check photo #3 in post #51 and photo #2 in post #59 in this thread. They both show the relative position of the transmission to the frame/floor pan, kind of.....
Old Jun 2, 2010 | 09:57 AM
D.Mac's Avatar
Dan,
I find there are three lengths of th400 rear housings, the most common is about 9" long, and I think that will work the best. There is one thats about 13 1/4" long, but it is much less common, any idea what your's is?-can't tell from the pics. Mine is the short, 4 1/4", length, and it sure ain't gonna do it. Any pics anyone has would be welcomed.
Doug.
Old Jun 13, 2010 | 06:24 PM
olds425's Avatar
I have an Olds 350 in my '42 Chevy, I think they are similar from the cowl back. If pics of mine would help I can take some. I would love to see pics, these 40's GM cars are my favorite.
Old Jun 14, 2010 | 05:38 AM
Oldsguy's Avatar
Past Administrator
Doug,
Sorry I missed you question last week. I will measure the tailshaft and let you know but from memory I want to say 9 inches. I wasn't aware of the longer one, maybe used on trucks?
(you should have PM'd me, again sorry I missed it)
Olds luvr
Oct 25, 2018 09:14 AM
MDchanic
Drivetrain/Differentials
27
Jul 8, 2011 03:20 AM
4-Speed
Mar 30, 2011 11:20 AM
trackz man
Mar 25, 2011 12:47 PM
club442
Jul 10, 2009 05:25 PM
