55 radiator
Old Jun 10, 2010 | 06:00 PM
doc93's Avatar
55 radiator
Dose anyone know or could check their cap and let me know what lb. size it is for a 55 324 thanks.
Old Jun 10, 2010 | 09:38 PM
hotrodj54's Avatar
hey ive got a 7lb cap on my 56 324..................john
Old Jun 11, 2010 | 05:41 AM
doc93's Avatar
Thats what I have but it dose not seem to be holding.
Old Jun 11, 2010 | 06:18 AM
rocketdownunder's Avatar
goin crusn in my55 olds
Hi doc93
my 55 has a 7 on it , it looked abit rusty so i orded a new one from fusicks that was a 7 , so i would say your one is stuffed if its not holding pressure.
cheers chris.
Old Jun 11, 2010 | 08:26 AM
Tedd Thompson's Avatar
radiator
Doc 93, Mine is a 7lb also. When I replaced my raditor it had a 14lb cap on it and the shop owner commemented that if I wanted my radiator to live I should replace it with the correct 7lb cap, seems the old system won't take the extra pressure for an extened time.
You might need a recoar or other issues may be the problem, perhaps the T stat is shot....Tedd
Old Jun 11, 2010 | 11:23 AM
doc93's Avatar
I just put a new stat in it a couple of weeks ago ( which there was none )and I will try a new cap and see if that works. I just wanted to make sure that was the right size and that for the info too.
Old Jun 14, 2010 | 09:39 AM
doc93's Avatar
Located a new cap and put it on so far so good. Thanks for the info guys.
Old Jun 15, 2010 | 12:18 PM
Fletch's Avatar
Just had to recore my 57 radiator... 7 lb cap.. puked until some of the real high water was expended, 100 degrees in Dallas.
Old Jun 15, 2010 | 04:16 PM
doc93's Avatar
What did the charged you for a recore?
Old Jun 15, 2010 | 05:31 PM
Fletch's Avatar
doc.93.... $450... brass core.. Happy to find someone to fit core to OEM tank and supports. I think it ended up a 3 row...... still holds a great deal of water.
Fletch
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
JONESY
Jan 11, 2005 09:19 AM
Bill
Feb 11, 2004 04:29 PM
