Part numbers needed.
Old Dec 3, 2010 | 05:58 AM
360scamp's Avatar
56 olds 324 I need a thermostat 195* and the fuel filter that goes under the glass in the pump. All the local part stores' books only go back to 62 even the only non-chain store left in the area.
Old Dec 3, 2010 | 07:49 AM
citcapp's Avatar
Try Rock Auto on the internet and Fusicks too
http://www.rockauto.com/
http://www.fusick.com/
Old Dec 3, 2010 | 10:39 AM
hotrodj54's Avatar
well the only place i know of to get the filter that goes in the pump is fusick...the stat should be able to get it anywhere. im suprised to hear the parts store only goes back to 62, rock auto will be the best bet for that then.............john
Old Dec 3, 2010 | 03:45 PM
hialeah56's Avatar
1956 holiday coupe
Napa auto parts
filter
http://www.napaonline.com/Search/Det...+50052+2052045
thermostat
http://www.napaonline.com/Search/Res...+50052+2052045
I didn't see a 195 degree thermostat in napa but I did see a 192 in autozone
http://www.autozone.com/autozone/par...3_0_1633_93207
I always look up parts before going to the auto parts and take them their part number makes my life wayyyyy easier. Also take the part in hand and compare prior to buying the new one, just because they say it fits don't make it so.
Old Dec 5, 2010 | 03:35 PM
360scamp's Avatar
I got everything i was looking for except the fuel filter. The Fil 3034 that is listed on NAPAs website is not the right one for a 56 Olds 324 at least not mine (240HP 4bbl in a super 88). It is too small in diameter and the center hole is too small and wont fit in the pump. Right now I soaked the one that was in the pump in carb cleaner and put it back in. I will also run another filter in line.
Old Dec 7, 2010 | 03:10 AM
Yellowstatue's Avatar
Try TSC for your filter and glass bowl...some tractors use the same size
Old Dec 7, 2010 | 06:08 AM
OLDZGUY's Avatar
Talking Just for info: Per Olds Parts Book
-original equipment, 1956 324ci Engine
*Group#1.246 Thermostat, Engine Water Temperature
Part# 563219 1941-59 160*
Part# 3749086 1941-59 180*, also 1963 except F-85, all 1964-65 except V-6
*Group# 3.900 Pump Assembly, Engine Fuel & Vacuum
Part# 5621656 1955-57 1st Type, also 1958 w/o a/c (w/ strainer & glass bowl)
* note for 1955-56 also order Part# 444024 reducer bushing.
*Group# 3.904 Gasket, Fuel Pump Mounting & Strainer Bowl
Part# 585466 Gasket, Pump Mounting 1949-64, except F-85 & J88
Part# 5593455 Gasket, Strainer 1st Type 1955-57
Also Part# 5590039 Gasket, Strainer Bowl 1949-60, 1958-59 except a/c
*Group# 3.910 Strainer, Fuel Pump
Part# 5620861 Strainer (w/ bowl gasket) TYPE FP-57 1955-57 1st Type & 1959-60 w/o a/c
Per Chilton Manual: AC Fuel Pump Repair Kits for 1955-56 Fuel side D30 & Vac side D244
*Group# 3.925 Repair Kit, Engine Fuel & Vacuum Pump
Part# 5620673 1955-57 1st Type, w/ bowl & strainer (fuel & vac side)
*some 57 have 2nd Type w/ pulsator diaphragm
*Group# 3.925 Diaphragm Kit, Fuel Pump
Part# 5620665 1955-57 1st Type (fuel side)
*Group# 3.935 Eccentric, Fuel Pump Actuating (on engine camshaft)
Part# 566174 1955-64, except F-85
Old Apr 25, 2011 | 12:39 PM
drdunk's Avatar
i nead the same ac pat.2,159,196 fuel filter du you know where to fine that
Cutlass Crazy
Jul 26, 2011 01:30 PM
flatoz
Nov 12, 2008 11:55 AM
85LS
Aug 13, 2008 07:14 PM
JVO
Ninety-Eight
Mar 9, 2007 11:13 AM
dale394
Brakes/Hydraulic Systems
Jan 31, 2004 12:45 AM
