rear trans mounts
Old Oct 15, 2011 | 01:47 PM
golds56's Avatar
rear trans mounts
Hey guys i was getting ready to drop the engine and trans in tomorrow and while going through the parts boxes i found the rear trans mounts ,three of them one newold stock and the ones i removed from the car.Problem is the ones i removed were cobbled up by the previous owner ,they arent for the hydramatic ,he drilled the holes sort of close and then wobbled them out so he could get bolts in them,another reason it shook when i bought it and had the fresh engine rebuilt again.Does anyone have a source for these mounts i only need a left side rear trans mount and i dont want to pay a core charge i probably wont get back for the cobbler special repairs.Thanks Glen in michigan.
Old Oct 15, 2011 | 07:21 PM
hialeah56's Avatar
1956 holiday coupe
a bit pricy but here they are
http://www.nosmopar.com/query.asp?ma...section=MOUNTS
Old Oct 23, 2011 | 03:09 AM
golds56's Avatar
got em in thanks,they are still a pain to install though,but i did it and everything is properly torked down now.Next up carbs distributor and fuel pump and oil filter and and and.....can i get a picture of the distributor from someone,in the car with you pointing at number one plug wire on it.Could also use a photo of how the crankcase ventilator is located and if there is a bracket for it and where that bolts on.Thanks
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
78 omega 468
Aug 21, 2010 06:54 AM
panamracer
Jun 1, 2009 08:21 AM
flatoz
Mar 15, 2009 02:03 PM
