1940 olds info needed
Old Dec 16, 2011 | 03:19 PM
jimbo74's Avatar
hello i have a stock original 1940 olds 4 door sedan ,with the 230 6cylinder column shift std trans ,,i was wondering where to find parts if there is any info on website looking for old race stuff aluminum intakes and split headers if any info thanks ,i searched and googled and cannot find anything and for original parts i know alot of pontiac and chevy cars are the same parts ,,
Old Dec 17, 2011 | 09:52 AM
hialeah56's Avatar
1956 holiday coupe
look here this is a website that lets you look at all the craigslist sites together not just by area
http://www.allofcraigs.com/
and if you are just looking for restoration parts look at my signature under this post, in the olds parts heading
Old Oct 6, 2012 | 07:31 PM
40Ragtop's Avatar
Intakes & duals exhaust
If you search ebay "edmunds 2x1 oldsmobile intake" you'll find ONE- otherwise you'll have to have one made as well as an exhaust. There are a few guys who still dabble in splitting your stock exh/ try www.hamb.com
I was quoted $500-1000 by a local shop to make one from scratch.
The Chevy, Buick, & Pontiac 6 cylinder model engines are left hand or drivers side intake/exhaust, where as the Olds is right hand or passenger side. You may find something to fit, but the vac line hole will be on the wrong end of the motor, & if its an exh the downtube will point towards the front....RIGHT where your fuel pump is...
The other issue is IF you do get an intake- the stock carb flange is 2 3/4" where an aftermarket (edmunds/offy) is 2 15/16" just far enough off by about a bolt hole or stud with.
Call Carlos @ www.carbsonly.com & get your wallet ...ready.
Good Luck!!!!
Old Feb 14, 2014 | 08:22 PM
oldsmobile1915's Avatar
1915 and 46-48 Olds pro.
Originally Posted by jimbo74
hello i have a stock original 1940 olds 4 door sedan ,with the 230 6cylinder column shift std trans ,,...
It may help to know that engine is 238 cu in.... by having this information, you may find some parts that fit.
good luck
Old Feb 15, 2014 | 11:08 AM
mpolds's Avatar
1939 - 1952 OLDS Front HUBS & DRUMS!!!!!
If you would like a "winter special" on a couple of N.O.S. Front HUB & DRUM Assemblies -- call me now for best price!!!!
Craig -- 516 - 485 - 1935.... New York....
Also have Brake Shoes, Wheel Cylinders, Brake Hoses, Wheel Bearings & Seals, Emergency Brake Cables --- all U.S. Made!!!!!!!!!!!!!!!!!!
hackers
May 8, 2015 12:40 PM
west.56
Jul 22, 2014 09:02 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
oldsvair
Jul 13, 2009 05:46 AM
west.56
Mar 11, 2009 12:49 PM
