56 Olds 88 2Dr Hardtop rear quater panel
Old Dec 1, 2015 | 04:17 PM
monte56's Avatar
Trying to find rear qtr panels for 56 Olds 88 2dr hardtop...looking for the section between the door and wheel well. Found some from a 54. Anyone know whether they will work? Thanks
Old Dec 1, 2015 | 04:31 PM
I moved your thread to the vintage section section. Hopefully these guys can answer your question.
Old Dec 1, 2015 | 06:50 PM
monte56's Avatar
Thanks..looking for info on the part compatibility.
Old Dec 1, 2015 | 09:03 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I think that front part of the quarter panel is probably the same but can't say 100%.
Old Dec 2, 2015 | 05:23 AM
Rocketowner's Avatar
X2 .54-56 I believe should work ,but what I believe + $1 will get you a Sweet Tea @Mc Donald's. The problem area would be the area around the perimeter of of the fender skirt.The fender skirts and wheel opening on '56 Olds are the same as '55 4dr. Hardtop,but different from '54 And '55 2 dr. Hardtop. Hope you can find exactly what you need from a '56,but if not send me a picture of the damaged area,and we can go from there. Do you have access to a '57 Bel Air 2 dr. that you could do some comparing and measuring.Rustrepair.com has these panels for a '57 Bel Air 2 dr for under $100 each.Just might take very little modifying.
Old Dec 3, 2015 | 11:01 AM
monte56's Avatar
Hi, I attached a sketch and pic of the rear qtr. This side of the car has been cut out the other side has not. Thanks for the help
Old Dec 3, 2015 | 03:38 PM
redoldsman's Avatar
The wheelbase opening is different on the 56. The 54 and 55 are the same.
Old Dec 3, 2015 | 04:28 PM
The actual wheel lip area (only about 2" wide)is the same as a '55 4 dr. Hardtop (both ('56 2 dr. hardtop and '55 4 door hardtop use the same fender skirts.Then you would have to fabricate the the flat 20" or so out of sheet metal.I would recommend you check out www.rustrepair.com and look at the ones for 1957 Bel Air 2 dr..AT under $100, it might save a lot of time. Larry
Old Dec 3, 2015 | 08:47 PM
redoldsman's Avatar
Looks like you are going to need rocker panels too. I think I have a repro set of those if you do. You might try Dessert Valley Auto Parts or CTC Auto Ranch for the quarter panel. They won't be cheap but will probably be less than all the metal fab required.
Old Dec 5, 2015 | 08:05 AM
twintracks's Avatar
I restored a '56 Chevy about 20 years ago. It sure was nice to pick parts from a catalog when needed. Only real (crazy) men tear into an old Oldsmobile.
Old Dec 5, 2015 | 08:38 AM
Tedd Thompson's Avatar
Sometimes a parts car is your best solution especially if you need additional parts. Unfortunately the parts that you need are the parts that rust out first.... Tedd
Charly9g
Jun 3, 2015 06:09 PM
steverw
Body work
Dec 7, 2014 12:47 PM
mighty mouse
Apr 11, 2014 08:05 PM
Neo1874
Oct 9, 2006 07:18 PM
<luvmyolds>
Jan 17, 2004 10:57 AM
