starter for 55 needed
Old May 31, 2014 | 09:04 AM
Tigerdog1's Avatar
"It was justified"
Hi friends. I am attempting to start my '55 OLDS 324cid after sitting for 20years(resto project I sadly need to sell) Everything looks good however my factory original starter is a "brick". Does anyone know of anywhere I can find a starter-ANY KIND-to use simply to make this thing crank over. I will keep the original to go with the car but rebuilding it at the moment is not financially an option. HELP PLEASE............you folks are the greatest, thanks.
Old May 31, 2014 | 09:47 AM
What is your starter doing or not doing, symptoms?
Old May 31, 2014 | 10:27 AM
Tigerdog1's Avatar
"It was justified"
Had it checked by a specialist. armature shorted, and the internals are basically disintegrating. This is odd because the car has been covered and stored. Simply looks like moisture got in.
Old May 31, 2014 | 10:35 AM
Is there a rebuilder close to you, check your yellow pages? Other than that maybe post an ad in the parts wanted section.
Old May 31, 2014 | 07:12 PM
Rocketowner's Avatar
There's a starter on eBay listing says '55-62 corvette/olds (shows 4 pictures and GM #'s)Buy now price $38.00. Might pay to check it out! Larry
Old Jun 2, 2014 | 04:33 PM
Tedd Thompson's Avatar
If the case is still good I would think the inter parts should be the same as other GM cars. A generator shop could tell you this in a few minutes....Tedd
I'm also in the California Sierras If you are close I may know a shop near you that can help....Tedd
Old Jun 2, 2014 | 04:48 PM
Sorry I just re read your post and I see funds are the problem. I'll look through my junk and see if I have something that might work that I can let you use, no guarantees, every time I promise something I find It's been pilfered. I'll PM you if I find one tomorrow or the next day...Tedd
Old Jun 5, 2014 | 07:55 PM
Tigerdog1's Avatar
"It was justified"
Thank you Tedd, Larry, And Eric for your time. I will post if I make any progress. Tedd-I am 30 mins from Quincy,CA. I had it checked at John's Automotive-Electrical Specialist in Quincy.
Old Sep 9, 2014 | 09:27 PM
Tigerdog1's Avatar
"It was justified"
Update on my '55. Got the original starter completely rebuilt (omg it is magnificent)Special thanks to the gang at Buchanan Auto Elect. in Oakland,CA. "at least the case was still good". Car fired right up after new ignition points, cleaned the plugs, and fresh fuel. No belching smoke, idled right away. Got it warm, changed the oil & filter, lifters sound good-after sitting for TWENTY years.
Thanks again to those "looking out" in my previous posts. I'll try to get a vid posted in case anyone is interested in the car.
Big Dawg
Oct 18, 2014 06:57 PM
briane
Jun 30, 2014 07:48 PM
scott71
Mar 5, 2010 10:58 AM
Bens71442
Jan 3, 2006 03:33 PM
Lobo
Jun 29, 2004 09:05 PM
