53 Olds Door Card Removal
The PS door on my Olds only opens from the inside, so I thought i'd take a look to see whats going on, having never owned an 53 Olds before it was going to be a learning curve, all the various trim screws were obvious and visible and I knew there would be C Clips behind the window and door cranks, but what I didn't bank on was over an hour of picking and poking and head scratching to find and access the C Clips.
It turns out they are hidden by a thin plate which is held tight against the back of the crank by a spring, simple when you know, then once the cranks are off pry loose around the the edge to release the pins undo the small screw in the armrest, and lift the panel upward off the channel at the bottom of the door.
So here they are and how to find them for anyone else like me who owns a 53 and needs to get the door card off.
Hi Nigel,
They make a slick little tool for popping off the C-clips, but you have to be ready to catch it before it flies across the garage. Check online, or mine came from Snap-on tools. The same C-clips were carried forward into the 1970s on GMs, and others.
I know Tedd, I think I was the first person in there since it rolled off the assembly line....cool. Had to stick the sound deadening sheets back as the had fallen off inside, I put them back exactly as they were.
