1954-1956 owners
Old Mar 20, 2015 | 07:11 AM
Trax5688's Avatar
1954-1956 owners
Just wanted to ask you 54 to 56 owners what parts on these years are interchangeable. I have a 56 4 door and I want to know for a rear bumper, only a 56 or others years work? Also fender skirts. Thanks guys.
Old Mar 20, 2015 | 07:28 AM
Olds Dad's Avatar
Collector of Stray 55's
Bumpers are '56 only and I believe fender skirts too since the wheel opening is different on '56.
Is yours a sedan or a pillarless (Holiday)?
Old Mar 20, 2015 | 07:31 AM
Trax5688's Avatar
Sedan. It's a super 88. I was told from the previous owner.
Tedd Thompson's Avatar
I think the rear bumper will fit (bolt up) off a 55 but will not look correct.Pull up some image off of google and see if you could live with it....Tedd
Old Mar 20, 2015 | 07:33 AM
Trax5688's Avatar
Ok. The previous owner roll panned the rear end. So I want to put a bumper back on it.
Old Mar 20, 2015 | 07:37 AM
Olds Dad's Avatar
Doors will interchange between the 54-56 and I believe the deck lid, but the nose sheet metal is 56 only as is all the trim except windshield and rear glass.
Dash is 56 only. Most other interior pieces will interchange but may not necessarily be 'correct'. 56 changed from the "world" insignia on the steering wheel to the 'stars' - but they will interchange.
Engine will interchange but they do have '56 only heads and other things. '56 started using the Jetaway transmission but some still used they Hydra-matic. If you have "Park" you have the Jetaway, if no "Park" you have a Hydra-matic.
'56 also started using a rag joint for the steering where 54 and 55 did not.
A lot is different...a lot is the same. If you have specific questions post them up.
Good to have you here...we need more
Old Mar 21, 2015 | 08:01 AM
Trax5688's Avatar
Thanks a lot
Old Apr 22, 2015 | 06:54 AM
Cratethis's Avatar
I was just trying to find out information on this. I have a 55. Got a guy close to me that has a 54 he is parting out. I could use a more solid hood. My gut tells me they are different. Are they? or can they be swapped?
Old Apr 22, 2015 | 08:04 AM
Ozzie's Avatar
Post
The part number for the 1954 Olds hood is 564869; for the '55 it's 566563. I don't know if they will interchange. Hollander shows no interchange for the 1955 Olds hood.
Old Apr 22, 2015 | 08:15 AM
The two hoods have a very different look and if they did interchange the car would look strange to me. Google up a few images and look at the difference... Tedd
Old Apr 22, 2015 | 08:42 AM
Cratethis's Avatar
I didn't think so. With all the different angles of pictures that people take, it isn't the easiest to tell. Thanks for the help!
Takid455
Jul 31, 2014 11:18 AM
evans_78
Mar 20, 2013 12:46 PM
Hurst
Cars Wanted
Nov 24, 2009 08:45 AM
TABORHEAD
Cars Wanted
Dec 20, 2004 09:30 AM
