1948 model 66 fastback coupe tires
Old Feb 17, 2016 | 10:34 AM
bobmobile's Avatar
So what tire options do I have to use on my car? I have the original 16" tube rims and need some cheap used tires. What is a good full size tire and can I put them on my old tube rims?
Old Feb 17, 2016 | 10:43 AM
You need to go with an equivalent type tire with a tube. I don't know what the market is on used tires for that era rim.
Old Feb 17, 2016 | 11:32 AM
bobmobile's Avatar
Correct! I need to know or get advice on what my options are, based on those parameters. thanks for the comment.
Old Feb 17, 2016 | 11:52 AM
I would assume that you can get away with anything from 600 to 700-16's. 28.56 - 31 inch diameter.
For reference:
https://www.cokertire.com/tires/styl...blackwall.html
Old Feb 17, 2016 | 01:55 PM
47 Convertible's Avatar
16 inch tires for 48 olds
For reference:
__________________________________________________ _____
x2 on those tire sizes and you may as well not look for cheap used tires in those sizes. 16 inch tires on cars went the way of the Dodo birds about 1950. I believe 600x16 were standard on 60 series as the 60 series was about the same size as Chevrolet and Chevy used 600x16. Also check Diamond Back Tires www.dbtires.com I hear good things about them.
Jerry
Old Feb 18, 2016 | 08:30 AM
Tedd Thompson's Avatar
You might try 205/70/16's in a modern radial tire, they may be a little wider but many small SUV's run that tire and there should be some around in used tire shop.... Tedd
Old Feb 18, 2016 | 08:57 AM
I don't think he can put tubeless tires on a rim that requires tubes, correct me if I'm wrong.
Old Feb 18, 2016 | 09:48 AM
70cutty's Avatar
Beer Connoisseur
You can't run tubeless tires on that wheel but you can run tube and tubeless tire together.
Old Feb 18, 2016 | 01:14 PM
Chesrown 67 OAI's Avatar
I have a pair of blackwall 600-16 Continental tube-type that i bought originally for my 42 Olds and switched them out for wide witewalls. Like new condition -- yours for $75 for the pair --FOB Dover OH -- pm if interested
I actually have all 4 if you may be interested -- (150 for all 4)
Old Feb 18, 2016 | 01:15 PM
[QUOTE=bobmobile;896456]So what tire options do I have to use on my car? I have the original 16" tube rims and need some cheap used tires. What is a good full size tire and can I put them on my old tube rims?[/QUOTE
see message below
bobmobile
Jul 7, 2014 04:55 PM
auto doug
May 6, 2012 03:05 PM
auto doug
Feb 11, 2012 04:43 PM
Donaldo7
Oct 11, 2011 05:40 AM
48fastback
Sep 25, 2009 01:39 PM
