53 DS Lug Nut Removal
Old Feb 25, 2016 | 08:02 AM
Eightbanger's Avatar
For those in the know this will be no surprise...
I removed my front PS wheel to do some work, then moved to the DS to do the same, but for the life of me could not remove the lug nuts, I drowned them with WD40, I hammered them and I jumped on the breaker bar but they wouldn't budge.
So in a last ditch attempt before resorting to cutting them off I tried tightening them slightly to crack the corrosion I assumed was in there holding them tight....guess what happened? if you haven't already, they came right off as they are left hand thread on the DS
Old Feb 25, 2016 | 08:18 AM
Oldsmaniac's Avatar
My 59 has L stamped on the wheel studs on that side.
Old Feb 25, 2016 | 08:20 AM
jensenracing77's Avatar
lol, I did the same thing in 2002 on a 62 Dynamic 88. They did this for around 25 years from what I understand.
Old Feb 25, 2016 | 08:26 AM
Most of us have been there.
Old Feb 25, 2016 | 08:44 AM
CRUZN 66's Avatar
Olds Fever
For a long time I thought only Chrysler products had left & right hand nuts, until I purchased my first older Olds way back when....
Old Feb 25, 2016 | 08:54 AM
Glad im not completely alone then, I really hope i've not damaged anything.
Now before I get to the back wheels....they're not going to be push, twist and release or something? lol
Old Feb 25, 2016 | 10:50 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
WD40 is not a penetrant. Try PB Blaster or Castle products "Thrust". To date there has not been anything I cant bust apart with the above, with heat or with pneumatics. Have you tried heat then quenching? If you dont have air tools why not drive it to a shop and have them use a 1/2" impact on them. All of these suggestions are much easier than cutting and replacing studs. Thats workin harder IMO...
Old Feb 25, 2016 | 11:06 AM
Thanks for the suggestions, but none of the above would have worked either as it turned out the nuts had to be turned clockwise to remove...lol
Old Feb 25, 2016 | 02:38 PM
Yellowstatue's Avatar
^^^ CCW...Counterclockwise.
Old Feb 25, 2016 | 03:10 PM
On the PS it was the normal CCW to remove, but as I said in my original post, to remove the lug nuts on the DS it's the opposite CW to remove.
Old Feb 25, 2016 | 04:03 PM
Rocketowner's Avatar
We hired a boy right out of trade school years ago who was very determined that he could outdo anyone else .We were rotating the tires on an early model Olds and had both ends suspended with those wide air powered bumper jacks.He challenged me that he could beat me getting his two wheels off, rotated,and back on ,faster than I could. While he was rolling one around to the other corner,I picked up a right hand thread and swapped it to the other side, and put mine back on then ask him if he was ready to let his jack down.He was really mumbling about one of the lug nuts would not start to thread back on. I could not hold back a laugh,and had to tell him what I had done. Larry
Old Feb 26, 2016 | 06:47 AM
If you over torqued the drivers side studs consider replacement...with same thread direction as passenger side. Problem permanently eliminated. Cheap insurance of not losing a wheel at speed.
Old Feb 26, 2016 | 02:48 PM
Yes...to remove, I was thinking of tightening.
Old Feb 26, 2016 | 04:21 PM
Two very good points...Cheers, I think I would feel better for having done this.
w-30dreamin
Oct 14, 2014 08:51 PM
cuttyroe
Apr 18, 2011 07:14 PM
69CuTlass S
Sep 18, 2010 02:38 PM
fjross
Sep 13, 2010 07:34 AM
yeahbuddy
Wheels and Tires
Aug 26, 2010 09:38 PM
