Towing a small trailer with my 56
Old Jan 30, 2016 | 12:02 PM
sweet56olds's Avatar
I have seen other cars pulling a small camper trailer like an old Shasta. I have my eye on a 14 ft 50's Shasta that is close to where I live. I would think the Olds would tow it since it only weighs about 1800lbs. Has anyone towed something like this and where would I find or modify a hitch to attach to the frame?
Old Jan 30, 2016 | 12:52 PM
I would think it will tow it, my dad towed a similar trailer when we were kids with a 64 Plymouth, 318/auto. As far as a hitch, Uhaul stores used to fab and install them or perhaps a welding shop.
Old Jan 31, 2016 | 06:06 AM
rustyroger's Avatar
'87 Delta 88 Royale
If it is automatic DO add a transmission cooler. DON'T ask me how I found this out.
Roger.
Old Jan 31, 2016 | 07:42 AM
Tedd Thompson's Avatar
If it is a jetaway it is setup for a transmission cooler....Tedd
Old Jan 31, 2016 | 08:55 AM
Magna86's Avatar
I'm not sure all uhauls will fab a hitch for you. Where are located because? They have a place in Tempe, AZ that would do it. Otherwise go to a fab/welding shop to have them make one. A trans cooler and rear air shocks are a must. When I put one on the 71 to tow my 66 on a dolly I found a universal that was wide enough and didn't hang too low. (Had to call manufacturer for the specs) Then I just drilled holes and bolted it on. I wish I would have added the air shocks but it handled towing well.
Old Jan 31, 2016 | 08:32 PM
47 Convertible's Avatar
Spend extra dollars and get the anti-sway option for the hitch. Without one if the trailer should start to sway back and forth it becomes hard to control and dangerous.
Hopefully you are the exception and have lots of towing experience and top notch equipment but I-5 in my area of SW Washington is littered every summer with wrecked camper trailers generally being pulled by cars with insufficient bumper hitches including no anti sway and independent braking on the trailers that depends on slowing down to set trailer brakes. Its the steep downhills or strong sidewinds that set up the swaying but poor equipment and lack of experience that turn swaying into wreckage and injuries.
For my buck there is nothing as good as having the trailer brake hooked to the car and integrated with car braking or at least a handle/switch in the car to activate electric brakes on trailer to help slow things down.
Jerry
Old Feb 1, 2016 | 09:00 PM
I have been towing car trailers, driving motorhomes while towing cars and boats and also towing motorcycle trailers. I could tell a few sway stories. The trans cooler, elect brakes etc and all that was mentioned was on my list. This is just a small Shasta 14' camper so it only weighs about 1800 lbs. Looks just like the one in this pic.
Old Feb 2, 2016 | 10:46 AM
rustyroger's Avatar
'87 Delta 88 Royale
Shouldn't be a problem, my '87 fwd Olds 88 copes well with a 1700lb trailerhome over here.
Roger.
tecar442
Aug 10, 2013 08:04 AM
texasred
Jul 7, 2010 03:43 PM
citcapp
Jan 31, 2009 04:01 PM
85LS
Jul 1, 2008 06:21 AM
ncwitte
Ninety-Eight
Apr 1, 2007 01:42 PM
