PDA
View Full Version : Electrical
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Headlight upgrade advice/help
  2. Electronic ignition conversion
  3. Alternator
  4. Identify connection
  5. 1972 Supreme alternator question
  6. New distributor
  7. + battery Cable
  8. 66 Vista cruiser instrument cluster pin connections
  9. Park lamps overpowering turn signal visibility
  10. Distributor grounding and bonding
  11. power windows
  12. Remove Instument Cluster
  13. 1971 Lansing Open Face Alternators
  14. What are these two connectors? 1971 Oldsmobile 442
  15. 67 Olds 442 horn mounting brackets
  16. 1970 442 wiring/electrical/ignition question
  17. 1972 Cutlass wires hanging under dash need ID please
  18. 1972 Cutlass Power window (dr side) issue
  19. Voltage at battery vs. alternator
  20. Fuel sender unit
  21. Mysterious electrical box under dash
  22. Kickdown throttle transmission switch install
  23. Horn short
  24. Columm to console shift swap -column wiring different?
  25. Identifying an unknown connection? Help '68 442 vert
  26. Starter Very Slow To Disengage
  27. 68 AM radio resto & upgrade
  28. Electrical gremlin
  29. 1972 Cutlass headlight harness routing
  30. Voltage drop issue
  31. 69 Fuel tank sender that fits properly
  32. Instrument cluster lights
  33. Blower Motor Ground
  34. Car Battery Life Expectancy
  35. 1966 Cutlass Convertible Top Switch Replacement
  36. Center Console Shifter Position Light 75 H/O
  37. Distributor question..
  38. Distributor breaker plate ground wire repair
  39. Unknown connector
  40. SI to CS alternator wiring on 70 442
  41. 1970 442 Wiring Identification
  42. Mallory cap dual point burnt center button
  43. 1984 Delta 88 brake and turn signal lights on
  44. 1970 442 Identifying relays wiring under hood...
  45. 1969 442 Black Battery Cables
  46. Alternator for 1959 Olds 371
  47. Cooked mallory dist cap
  48. 1970 442 Power seat diagram
  49. 1970 442 Gauge Identification
  50. 1950 Rocket 88 voltage regulation
  51. 1970 442 Convertible Wiring diagram
  52. What company have you used for reproduction wiring harnesses?
  53. What is this, and can it be replaced?
  54. Squealing blower motor - fixes? Hacks?
  55. license plate light has power but bulb not responding
  56. Radio turns off and lights flicker
  57. G-body gauge cluster
  58. 1969 442 Fuel Gauge Not Working
  59. courtesy light stays on
  60. 1972 oldsmobile cutlass s
  61. Just picked up a 84 H/O and there are a few wires cut
  62. Electrical Overhaul
  63. Correct battery for a 1984 Hurst/Olds
  64. 12 volt keyed source
  65. Flasher module location
  66. 1967 Cutlass Supreme Convertible Top Operation Failure
  67. No Power to dash
  68. Connecting/testing Delco radio - pinout of white 6-pin connector
  69. 72 Cutlass dash wire help
  70. Battery Central Mall.
  71. '67 Toronado brake lights not working
  72. 1990 Olds 98 Code 26 Flashing
  73. need help with distributor and ignition coils
  74. Radio options for 72 Cutlass
  75. why is one radio knob longer than the other?
  76. Convertible Top Operation
  77. Delco AM, AMFM 8 track player repair
  78. what can cause a slow turn signal
  79. Found this module under dash
  80. Looking for Reputable Shop to Remove Radio & Other Electrical Work
  81. why does the fuse blow when I turn the headlight switch knob?
  82. Wiring ID - 70 Cutlass
  83. Dash housing electrical issues Cutlass/442
  84. 67 Oldsmobile 98 turn signal issues part 2
  85. 75 Hurst Olds (cutlass) removal of rally gauges
  86. Parking brake light
  87. light switch question - 75 Olds and others
  88. Trunk release ckt for 67 442
  89. 68 cutlass underhood light.
  90. 75 Olds H/O fuel/temp/pressure gauge issue
  91. 69 brake light issue
  92. 1969 Cutlass Tail Light Issues
  93. Trying to identify a wire
  94. 1967 Oldsmobile 98 Convertible electrical question on brake lights
  95. 66 Cutlass / 442 dash harness
  96. What is this part?
  97. '69 tail light socket
  98. Starter issue
  99. Removing AM/FM Stereo From '71 Cutlass/442
  100. Dome light
  101. 1971 Cutlass/442 AM/FM Stereo Radio Repair
  102. 68 cutlass instrument gauge wiring
  103. Points inspection
  104. Electrical issue with AC on a 1987 Delta 88
  105. Buzzing issue
  106. Pack Con Connector Body Needed
  107. Electric Flashers for LED bulbs
  108. 67 Oldsmobile 98 convertible wiring schematic
  109. wiper motor issue
  110. Over charging....16+ V!
  111. Heater Control Panel Light - 67 Cutlass
  112. H/O Tachometer repair and info
  113. 66’ cigarette lighter electrical issue
  114. 1980 Cutlass supreme diesel to gas wiring
  115. 95 Aurora
  116. '67 Toronado - right rear blinker/brake lights not working
  117. I’m no electrician but this don’t look right!
  118. termial crims
  119. Hazard lights
  120. 1964 Cutlass Convertible Wiper Motor Issue
  121. Rear Tail Light/Turn Signal socket on 75 Hurst Oldss
  122. Trying to find this pig tail near transmission
  123. Could it be the alternator?
  124. Looking for help w/color engine wiring diagrams for 85 Cutlass Supreme 3.8 2bbl NA
  125. Fusible Link Replacement
  126. Horn button and Contact
  127. Battery drain
  128. Stereo install and trunk battery
  129. 1970 442 A/C wiring diagram
  130. 1961 Olds 98 Battery Group
  131. Fm Radio Hisses With Lights on
  132. 12vdc vs. 6vdc
  133. kickdown, pitch switch switch not working. 67 442
  134. Advice on unplugging a wiring harness plug from the firewall
  135. 61 dynamic 88 dash wiring?
  136. Center Console Glove Box - 75 Cutlass/HO
  137. 1970 Cutlass Supreme Wiring Harness
  138. '67 Toronado A6 compressor coil "clocking"
  139. Rear defrost harness?
  140. Slightly Brighter Reverse Light bulbs 1156 vs P21W LLB2
  141. Under hood wiring question
  142. 1987 olds cutlass cruiser: crank but no spark
  143. Trunk Light activation on 75 Cutlass
  144. 64 Cutlass no crank
  145. Headlight Switch & Dash Lights Dimming feature
  146. 1971 442 4speed NO Crank
  147. Blower Motor - Part Sourcing Help
  148. 1975 Hurst Olds (Cutlass Supreme)
  149. HELLA halogen sealed beams on 1964 olds?
  150. 1969 W31 4 speed positive battery cable routing
  151. Turn Signal Keeps Failing
  152. 1970 Cutlass rear speaker wire routing
  153. 65 CHC wiring issues
  154. No Headlights
  155. Gen to alternator swap.
  156. MSD coil- ballast hook up?
  157. Hot start diagnosis
  158. Automatic start
  159. 65 F-85 won't start
  160. The generator burned out.Oldsmobile 98 1973
  161. any tips for removing headlight switch 61 dynamic 88
  162. Dash light acting strange...
  163. Courtesy light question..
  164. Footwell Bulbs Replacement '71 Cutlass Convertible
  165. Purple Solenoid Wire Heating up
  166. Tail light sockets
  167. Power seat motor 60s
  168. '66 Tilt-tele turn signal switch
  169. 1972 Cutlass 442 under-hood light connection and function questions
  170. Alternator upgrade(?)
  171. Can you identify that place for connectors...
  172. Starter solenoid
  173. Big electrical problems - 1972 Oldsmobile Cutlass S Faux-Four-Two
  174. wire harness
  175. 4 terminal wiper motor
  176. Harness connections, solder or crimp
  177. Alternator Wiring Diagram
  178. Battery losing charge
  179. Turn Signal Switch Extra Wires
  180. Turn signal switch
  181. 70 442 A/C No High Speed
  182. 1970 circuit breaker for power options
  183. Power window switch
  184. Rear window switch
  185. Could my windshield antenna have a broken wire?
  186. Wiper motor interchangability
  187. Ignition Stuck
  188. 1955. 88 back up lamps
  189. Headlamp Age?
  190. What is this on my Wiper/Washer pigtail?
  191. Disconnected Wiring Connection ID - `97 Cutlass
  192. Help with electric choke relay install
  193. Determining Wire Gauge Size
  194. Tachometer
  195. 72 Convertible Alternator
  196. Dash lights
  197. 1969 442 short troubleshoot
  198. wiper wiring
  199. Blinker insanity check
  200. Need a 94 amp alternator, please advise
  201. 1970 Cutlass dash cluster lights on all the time
  202. Going back to external regulator alternator.
  203. Power Window Issue 1968 Cutlass
  204. 76 Cutlass Seat Belt Warning System?
  205. 67 turn signal switch tilt column issue
  206. lens screws
  207. Battery Cable Lengths
  208. Wiper Motor Open Resistor Fix?
  209. rear quarter power window motor replacement
  210. Please help
  211. 1967 cutlass wiring diagram
  212. 1968 Cutlass S Center Console Wiring Harness
  213. Lights affect gauges
  214. Power Window relay ?
  215. After market Power door locks and trunk
  216. Are the hi beam stomper switches serviceable?
  217. Power window/seat wiring diagram 1966 Ninety-Eight
  218. Radio, turn signals, dash losing power car runs fine
  219. Why are you still driving on stock headlight bulbs?
  220. 70 cutlass dummy GEN light NEVER TURNS ON!!
  221. Flasher module 2nd time going bad
  222. Remove warning chime on 84 98
  223. Fast Indicators & Relay Locations + 2-Pin Cables
  224. Brake light switch replacement
  225. Alternator, 72 H/O, appears to have been monkeyed with
  226. 1961 Oldsmobile (Dynamic 88, Super 88, 98) Wiring Diagrams
  227. HEI distributor clamp
  228. '61 Super 88
  229. 1968 442 starter solenoid wiring?
  230. Wire gauge please..
  231. 1994 Cutlass Supreme Coupe- remote entry receiver replacement
  232. New gauges sets experiences
  233. Battery / Generator issue
  234. Alternator?
  235. ‘67 442 Unknown wire question
  236. ALternator wiring...
  237. Wiper switch for 62 98
  238. '86 Olds Cutlass Supreme Turn Signal Issue
  239. Marker Light/Turn Signal
  240. Suddenly no Clock, Domelight, Rear View Mirror Light and Cigarette Lighter
  241. Horn Issue - 69 Cutlass
  242. 1 more wire
  243. Replaced Steering column now not turning over
  244. 70 Cutlass Headlights - All 4 high/low wiring
  245. 1964 Dynamic 88 wiring schematic
  246. Car will not shut off :(
  247. TCS Solenoid Wiring - 1970 442
  248. 1966 Cutlass/442 Dash Electrical Harness
  249. Compatible Wiring Harness for 1970 Oldsmobile 98
  250. Removing bolt on Alternator
