1 more wire
Old Mar 31, 2024 | 01:05 PM
Chuxter's Avatar
1970 Cutlass Supreme
1 more wire
I have 1 connector coming out of my engine wiring harness that I have not figured out where it goes. I have looked through the diagram and still having a rough time. TIA
Old Mar 31, 2024 | 01:29 PM
2blu442's Avatar
My guess is not factory. I say that because it looks like the brown wires are just jammed into the male connector. There's no female plastic piece the brown wires are attached to. But what year/model of car are you working on? If it is factory there should be something in the wiring schematic that reflects it.
Or am I seeing it backwards? Are either of the red wires connected or are they just in the background. Is it two brown wires in one male plug?
Old Mar 31, 2024 | 01:47 PM
Chuxter's Avatar
Sorry the red wires are behind the image of the connector. They are not attached to it is a 1970 Cutlass Supreme. 2 Brown wires in a female plug located before the alternator wires and oil and temp sensors..
Old Mar 31, 2024 | 02:10 PM
Chuxter's Avatar
Think I just figured it out. I have converted over to an internally regulated alternator, and this plug I believe went to the back of the old alternator. It has been many years since I have torn this down and didn't remember this. Does this sound correct?
Old Mar 31, 2024 | 03:04 PM
That plug, as wired w/ two Brown wires, would not have attached to a 1970 internal VR ALT. The ALT would have been a Blue wire & a White wire in one plug attached to back of ALT.
Old Mar 31, 2024 | 03:13 PM
2blu442's Avatar
I think the under hood light used one brown wire, and would be in that general area. But the two brown wires in one plug is not ringing a bell.
Old Mar 31, 2024 | 03:15 PM
I'm suspicious the two Brown wires emanate from the wiring harness then plug into another connector w/ one wire leading to the under hood lamp the other wire leading to the tail light feed from the main lamp switch.
Old Mar 31, 2024 | 03:19 PM
Only one other location I can think of which I'll capture in a moment off the wiring diagram. But this is the one I'm suspicious you might be evaluating...
Old Mar 31, 2024 | 03:32 PM
Of course, a wiring diagram doesn't provide the length of any wire & I can't say the length of the wire emanating from the Main Lamp Switch - yet, it's a possibility two wires emanate from one wire. Additionally, please note both the LH & the RH side markers have a two Brown wire feeds as you trace the Brown wire branch. I suspect you're looking at a lighting wire.
Old Mar 31, 2024 | 05:50 PM
VC455's Avatar
Barely Registered
That wire is the 12 V supply for the underhood light, which sits on the bottom of the hood above the master cylinder.
Old Mar 31, 2024 | 05:59 PM
Gary - I believe you're correct regarding the feed wire itself. But, as I recall, the actual Brown wire which connects to the underhood lamp has only one wire to the lamp itself doesn't it? It's been awhile since I re-wired my underhood lamp. I may be mistaken.
Old Mar 31, 2024 | 06:13 PM
Chuxter's Avatar
I am pretty sure this harness is from a later model that has the internally regulated alternator harness. So I think I won't worry about it unless I need it. LOL I am sure I bought it here so I'll look back and see what I bought. Thanks for the help.
Old Mar 31, 2024 | 08:01 PM
VC455's Avatar
Barely Registered
Norm, you are correct.
The double-brown wire in the Packard connector mates with a single-brown, which is the lead to the underhood light.
The first photo shows the connection between the double-brown and single-brown wires.
The next one shows the single-brown lead at the underhood light.
Connector is in the center of the picture nearer the right-hand side
The single brown from the connector powers the underhood light
Old Apr 1, 2024 | 05:15 AM
Originally Posted by VC455
Norm, you are correct. The double-brown wire in the Packard connector mates with a single-brown, which is the lead to the underhood light.
Phoenix8990
Jun 21, 2021 04:29 AM
Puppy boy
Apr 14, 2021 07:58 PM
oldsmoboogie
Mar 12, 2021 02:55 PM
tnswt
Oct 11, 2020 02:01 AM
Mark71
Aug 15, 2016 06:30 AM
