Automatic start
Old Jul 16, 2024 | 11:27 AM
OldsMcDonald's Avatar
From: In the Uk in an area called The Midlands (which are in the middle :-))
Automatic start
My car is a 1950 Rocket 88. Tonight I thought I would get it out and investigate some funny noises coming from the suspension - I’ll save that for another post. I have a habit of leaving it in reverse when parked up as, if I don’t, reverse makes a crashing sound when I try to engage - leave it in reverse and all is well. Tonight I tried putting it into neutral and there was a heavy grating/crashing noise like gears crashing or perhaps the starter not disengaging. The funny thing is it now tries to start (with the grating noise) whenever I try to put it in to neutral. No ignition key required, no starter button to be pushed just try and select neutral. I disconnected the battery and left it a while - no change. If I am very careful and ease the selector towards neutral - but not all the way, it will go into neutral without the crashing but a millimetre too far and it sounds awful. I’m guessing the gear on the starter is jammed but I thought I would ask before I start crawling under the car which is getting increasingly more difficult as the joints and muscles get older.
Old Jul 16, 2024 | 07:42 PM
Have you done any work on the starter or electrical system prior to this happening? You need to crawl underneath and see what is going on. Leave a battery cable loose and have a helper handy to test things and to disconnect the battery if it is the starter engaging.
Old Jul 17, 2024 | 01:29 PM
Hi Eric,
Thank you for responding.
I had not done any work on the starter or electrical system but I have sorted it out thank you. I was convinced it was electrical so thought I would look at the Neutral Safety Switch and the actual Starter Button. Not knowing where the Safety Switch is I looked at the starter button first - made sure all the connections were tight and hey presto - it worked.
Old Jul 17, 2024 | 01:36 PM
Glad you got it sorted and posted the fix.
maineolds
Jun 17, 2022 08:33 PM
Kestas
May 30, 2015 10:34 AM
teqdave
Nov 21, 2013 03:29 PM
pcard
Jul 23, 2013 04:56 AM
Salmonking
Jun 14, 2011 10:20 AM
