Radio, turn signals, dash losing power car runs fine
Old May 19, 2024 | 06:25 AM
Ggscutlass's Avatar
Hi all wile standing at idle or driving I will ghost loose power for no apparent reason, some times it will be when using two or more of horn, turn signal, radio, gen light will come on. Everything will come back if I wait or simply turn car off and on. Alternator replaced with one wire points replaced not voltage regulator voltage is fine…. Do I replace agu s to painless blade fuse box? Anything maybe simpler ?
Old May 19, 2024 | 09:39 AM
What year Cutlass? Does the engine turn off when this occurs? Can you force it at will to do this?
Old May 19, 2024 | 10:20 AM
Ggscutlass's Avatar
its a 1966 engine has full power and runs normally it is just accessories
Old May 19, 2024 | 10:53 AM
Sugar Bear's Avatar
Symptoms of a weak charging system or a poor electrical connection. What is the battery voltage when this occurs?
Old May 19, 2024 | 12:52 PM
Ggscutlass's Avatar
brand new charging system, putting out over 14 and battery reading just over 13, hitting a bump can also cause
Old May 19, 2024 | 01:59 PM
Do the headlights go out also?
Old May 19, 2024 | 03:24 PM
Sugar Bear's Avatar
Did this start subsequent to any repairs/upgrades like the one wire alternator?
Try wiggling wires near the bulkhead to see if you can reproduce the problem. Feel the wires while under high electrical load for hot spots particularly at connections. This can also be done with an infrared point and shoot thermometer. Look for burned connectors.
Old May 19, 2024 | 04:00 PM
Ggscutlass's Avatar
no headlights and exterior lights work it’s all interior accessories and dash lights
Ggscutlass's Avatar
no replaced alternator after it started happening
joe_padavano
Jul 28, 2021 12:16 PM
EdwardB
Aug 22, 2020 01:19 PM
BSiegPaint
May 30, 2018 07:16 AM
charlierogers
Dec 20, 2012 02:35 PM
jpc647
Nov 18, 2012 02:12 PM
