The 64 Ninety Eight CSC build continues...I have a voltage conundrum that has me scratchin' my head
When the engine is running, the battery reads 14.8v at idle and 15.5v when I increase the RPM.
At the same time, the alternator shows 9.5v at idle and 10.5v under increased RPM.
I have a new voltage regulator on the way, but the situation doesn't make sense. If the alternator was weak, wouldn't the flow to the battery be much less?
i think the reading at the battery is the important one here, and it looks fine,
Yeah, I thought so too, but 15.5v is a little high. Don't want to boil the battery or start popping lightbulbs. Guess I need to put a multimeter on a light terminal.
How many butt connectors are on the battery charge wire?
Put the positive probe of your meter on the alternator charging wire stud, put the negative probe of the meter on the POSITIVE post of the battery. Start the engine, turn on every electrical item, then read the meter. Whatever the meter reads is how much voltage is lost in the charge wire.
Ideally, you shouldn’t see more than a couple tenths of a volt. You can do the same thing at the fuse box, just keep the negative probe on the positive post of the battery. Keep moving the positive probe around, hopefully you find a questionable wire.
Your discrepancy is a ground issue. Going to guess you didn't have a clean ground when testing the alternator.
Ah...okay! I will try again next time I'm out there. What if I run the negative lead right to the negative post on the battery? If I get a good reading, then I know it's a ground issue
Also make certain the positive wire from the alternator to the battery is in good shape with good connections and is large enough.
The battery ground should have a large connection going straight to the engine and a small connection to the body (fender or core support). Those connections also need to be clean.
Since he is getting voltage from the alternator to the battery, that wire is probably good.
If you measured the alternator voltage with the negative lead to the body of the alternator, you may have a poor ground path on the alternator body itself. It is quite common and may need a secondary ground lead. That may even resolve the regulator issue.
Once again, the fantastic members and wealth of knowledge in this form has helped me out!
I did some sleuthin' and found that the ground strap going from the alternator negative to the frame had snapped off at some point. So, I ran a new wire to the frame.
AND PRESTO! Alternator now make 15v at idle
and the battery has 14.2-14-4v at idle.
