New Battery and New Alternator, still less than 12 volts from battery, what else?
Old June 15th, 2017, 08:24 PM
Sledhead's Avatar
Hi, I recently replaced my battery and alternator in my 66 Dynamic. The battery is still only putting out less than 12 volts (11.2). The car won't start after I turn it off after jumping it. The GEN light was on before I replaced the alternator, but is not on any longer since I replaced it, but the battery is still below 12 when running. What else could it be? The voltage regulator? I bought the car a year ago. It was completely rebuilt with everything brand new inside the engine compartment including the battery, alternator, and voltage regulator (attached to the firewall). Before I give up and take it somewhere on a wild goose hunt, any thoughts on what I can do to troubleshoot it? Thanks!
Sledhead is offline
Old June 15th, 2017, 09:14 PM
RandyS's Avatar
I guess it could be a couple of things. The Alternator could be suspect of not producing 13+ volts, and it could be the regulator. Have the alt tested.
RandyS is offline
Old June 16th, 2017, 05:45 AM
Charging system description and troubleshooting begin on page 12-4 of your Chassis Service Manual.
The key test here is to disconnect the regulator plug from the back of the alternator and hot-field it by connecting the F terminal to the battery (+) and then run the engine at idle, slowly increasing RPMs while watching the battery voltage, with all accessories turned on at their highest settings (do not allow battery voltage to go higher than 16V).
If the alternator supplies voltage as it should, then the problem is your regulator (or connecting wires or terminals).
Read the CSM, then test your charging system as recommended there.
MDchanic is offline
Old June 16th, 2017, 07:44 AM
Olds Fever
CRUZN 66's Avatar
Have the alternator checked where you purchased it... Just because it's new or remanufactured doesn't mean it is putting out as it should... Also the voltage regulator can definitely be suspect even if previously replaced...
CRUZN 66 is offline
Old June 16th, 2017, 01:21 PM
stellar's Avatar
charge the battery and then retest and let us know what you get.
stellar is offline
Old June 16th, 2017, 05:47 PM
Tedd Thompson's Avatar
X2 New battery may have a dead cell. Not sure why I'm answering this, Steller has forgotten more than I have ever learned about electrical systems.... Tedd
Tedd Thompson is offline
Old June 27th, 2017, 10:04 PM
kuseetha's Avatar
Not giving you the fish but teaching you to fish :)
I had a similar issue in my Alfa with my refurbished alternator which was setup with an external regulator (since the internal diode pack was blown).
http://www.teamhealeytexas.com/Techn...Wiring%201.htm
I followed instructions and connected the sensing wire to the correct location (earlier it was connected to the alternator output. it is where the voltage is highest. so I connected it to a place where the voltage is the average of the system)
Now the voltage at the battery is 14.2V even running at full load.
kuseetha is offline
April 9th, 2014 04:13 PM
69ishHoliday
November 10th, 2013 08:08 PM
Diego
September 9th, 2013 08:34 PM
jpaulwhite
December 19th, 2011 07:26 AM
Quick Reply: New Battery and New Alternator, still less than 12 volts from battery, what else?
