'86 Olds Cutlass Supreme Turn Signal Issue
The turn signals on my 1986 Cutlass Supreme only work when the brake pedal is depressed. The hazard lights work just fine. I've replaced all the light bulbs, 1157 and 1156's. I've even switched bulbs from upper to lower sockets so many times I forgot which is on top, I think it's the 1157.
Has anyone heard of this issue?
The 1157 has two contacts as must its socket. The 1156 has one contact as must its socket. Confirm the bulbs are in correctly.
After confirming the bulbs are in correctly engage and disengage the hazard flashers a few times. If this fails I think you're heading into the steering column to replace the turn signal switch.
Sugar Bear...YOU NAILED IT!
I went to check the sockets and all four NEED an 1157 bulb! I don't know how the 1156s got involved but it was probably when I had the car painted a couple months ago and they replaced the old tail light housing with new ones that I bought online. I've had issues since I got the car home, and now I know why. Thank you again!
(They also replaced my old non-working power antenna and the new one doesn't work either, but I guess that'll be another thread...)
Feb 26, 2015 02:17 PM
