Replaced Steering column now not turning over
Old Mar 31, 2024 | 12:29 PM
Spencer66-442's Avatar
66 442 w/ Column automatic. My steering column had an issue. I removed it, went through it and put it back together.
After re-installing it, blinkers work, horn works, (so ribbon cable is fine) I put it in neutral and she rolls good...put in park holds tight.
There are two other wire connectors that go to the switch assembly (1993659) and I have the tang inserted into the correct slot on the assembly.
But when I try to start it...I get nothing. All other electrical working fine.
The starter was working great when I put it away in November.
Battery with a jump is at 13+ volts...
HELP!
Old Mar 31, 2024 | 12:43 PM
2blu442's Avatar
I would be sure its in park, then jump the wires across from the neutral safety switch to see if it will start. My guess is you have something out of adjustment on the neutral safety switch and if it starts when bypassed that would confirm it.
Old Mar 31, 2024 | 02:11 PM
Yes, check the neutral safety switch, the 2 purple wires at the bottom of the column.
Old Mar 31, 2024 | 03:00 PM
2blu442... Thank you very much. That did the trick.
Rocket Rob
Suspension & Handling
Jan 7, 2023 02:30 PM
Gary's 2 442-S
Dec 29, 2021 12:41 PM
dfire25
Jan 24, 2013 10:13 AM
4-Speed
Sep 11, 2010 08:20 PM
elcaminodave
Sep 12, 2008 07:01 AM
