Wiper switch for 62 98
Old Apr 23, 2024 | 04:13 AM
Mikeyt's Avatar
Mikeyt
Wipers aren't working and switch doesn't seem to click on any setting.
Is there a source for new or does anyone rebuild them?
Old Apr 23, 2024 | 06:04 AM
The correct switch is P/N 1993607. Search that number on ebay and Google. NOS ones do come up. (and I stole this photo from ebay, so not my little devil...)
Old Apr 23, 2024 | 06:58 AM
Oldsfan's Avatar
I replaced my switch and it turned out to be a motor problem. You might want to investigate further.
Old Apr 23, 2024 | 07:15 AM
Mikeyt's Avatar
Mikeyt
Awesome Thanks!
Old Apr 23, 2024 | 07:18 AM
Mikeyt's Avatar
Mikeyt
Can I have your old switch? 😁
Yeah I've only had her for 2 days so haven't trouble shot anything even it it turns out not being the switch I'm thinking as hard as it seems to find parts like these having a spare or two isn't a bad idea.
Old Apr 23, 2024 | 07:21 AM
rocketraider's Avatar
Oldsdruid
You have verified the wiper fuse is good?
Old Apr 23, 2024 | 08:08 AM
Mikeyt's Avatar
Mikeyt
I have not.
The switch just feels bad. Doesn't click on or off. Not sure it's even supposed to.
So yeah I have some troubleshooting to do.
Old Apr 23, 2024 | 02:51 PM
Mikeyt's Avatar
Mikeyt
You called that one.
The **** was loose thats why it didn't feel like it was doing anything.
Got 12 volts to the motor but nothing happens.
Did you replace or repair your motor?
Old Apr 23, 2024 | 02:56 PM
The wiper motor operates off ground/s provided by the switch.
Old Apr 23, 2024 | 03:30 PM
Mikeyt's Avatar
Mikeyt
Ok
When the switch is off and I check power at the motor there is no power. Switch on we have power so I believe it's functioning as it should or is there more to it?
Old Apr 24, 2024 | 06:36 AM
Oldsfan's Avatar
I took the cover off my motor and cleaned the old grease out of it. That stuff gums up after many years and things stop moving. Needs a good cleaning and re-lubing. It's a pain, because you've got to pull the wiper arms and cowling to get at the bolts to remove the motor.
Old Apr 24, 2024 | 06:51 AM
Mikeyt's Avatar
Mikeyt
Thanks for the reply
Definitely looks like a pain but it's gotta be done.👍
Old Apr 24, 2024 | 10:47 AM
Mikeyt's Avatar
Mikeyt
All was going well. Got motor out. Wasn't too bad.
Everything looked brand new inside so I decided to pop the cover off the motor itself. Very very bad idea.
I have no idea how I'm gonna get these bushings back around the rotor.
Old Apr 24, 2024 | 01:00 PM
Oldsfan's Avatar
What bushings?
Old Apr 24, 2024 | 03:37 PM
Mikeyt's Avatar
Mikeyt
What bushings?
brushes. Dang auto correct
Old Apr 25, 2024 | 05:11 AM
Supernice88's Avatar
Art S
There are instructions in the service manual, it involves using paper clips bent to a certain shape to hold the brushes back.
Old Apr 25, 2024 | 06:51 AM
Oldsfan's Avatar
Yeah, you probably shouldn't have gotten into the motor. I was referring to the mechanism.
Old Apr 28, 2024 | 01:49 PM
Mikeyt's Avatar
Mikeyt
I managed to get it back together with some blue painters tape and a lot of luck.
Now I need to figure out how to test it properly.
Old Apr 28, 2024 | 02:22 PM
This will give you an idea:
Old Apr 28, 2024 | 02:31 PM
Ah Ha! Brilliant. I always wondered how to test the PARK function w/ a jumper wire. That was kewl.
Old Apr 28, 2024 | 04:31 PM
Mikeyt's Avatar
Mikeyt
[QUOTE=oldcutlass;1567231]This will give you an idea:/QUOTE]
Thanks!
Old Sep 13, 2024 | 02:24 PM
Mikeyt's Avatar
Mikeyt
Cleaned all the old grease out of the motor and got it working!
High and low.
Washer pump engages but doesn't pump.
Pretty sure the orifices on the hose connector are clogged.
Still want to replace the switch. Have a search saved on Ebay.
If anyone sees one please let me know.
Thanks for all the replies.
Pug Wrangler
Jun 15, 2023 07:35 AM
spaceman_spiff
Jul 6, 2017 09:12 PM
Ron Scobie
Jan 6, 2013 02:41 PM
edfries
Dec 13, 2012 06:00 PM
toms1966rgtop
May 15, 2012 06:49 PM
