70 Cutlass Headlights - All 4 high/low wiring
Old Mar 31, 2024 | 08:36 AM
GvEmHellBama's Avatar
DD 70-S 455 w/bolt-ons
Has anyone modified and wired their headlights to where all four switch back and forth between high and low? Basically dual filament in all of them or LED/HID duals? If so, how did you wind up wiring it?
Old Mar 31, 2024 | 08:45 AM
Why would you want two low beams on each side?
Old Mar 31, 2024 | 11:19 AM
Adjust the beams for more light. 4 lights always on instead of two.
Old Mar 31, 2024 | 02:17 PM
You'll have to change the buckets and the connectors for the hi beams.
Old Mar 31, 2024 | 05:23 PM
Yeah, just use low beam parts in the high beam location. Easy peasy.
Old Mar 31, 2024 | 05:33 PM
I'm talking about making all four lights aftermarket dual filament and having them all swap back and forth. So basically I'll have all low beams, hit the foot switch and then have all high beams.
Old Mar 31, 2024 | 05:37 PM
Yes, I completely understand. As oldcutlass and I posted, using low beam bulbs and wiring in the high beam positions will do that.
Old Mar 31, 2024 | 09:16 PM
Ok, just making sure. That isn't going to overload the relay or anything?
Old Apr 1, 2024 | 05:42 AM
There is no relay. The headlights are hardwired to the switch, which contacts sizes to carry the current of the OEM headlights. Changes in current draw can overheat the switch.
Old Apr 1, 2024 | 05:54 AM
Since the switch already powers 4 hi beam filaments, I doubt that's an issue.
Old Apr 2, 2024 | 12:13 PM
Gotcha. I obviously need to get on AllData at work and print off a schematic lol
Especially if I swap to LEDs that won't draw the amps that halogen do.
Aighty, thanks guys!
Old Apr 2, 2024 | 06:52 PM
Supernice88's Avatar
Art S
If you manage to pull it off you are going to become a cop magnet.
Old Apr 3, 2024 | 12:49 PM
It's Alabama. They're not as strict as other states.
I drove my XJ like this for 6 weeks and never even got pulled over if that tells you anything.
Old Apr 3, 2024 | 07:28 PM
70cutty's Avatar
Beer Connoisseur
I have done that, Run 2 relays, 1 for low, 1 for high beams, use original wiring to switch them on.
No issues with cops, it's not like you are blinding oncoming traffic.
madmax442.com
May 1, 2023 10:51 PM
scrappie
Mar 14, 2022 06:26 PM
RUSTYCUTLASS70
May 29, 2021 06:21 AM
Malcolm11
Mar 28, 2020 06:55 PM
Retro1964
Jul 25, 2012 02:12 AM
