1961 Olds 98 Battery Group
Old Aug 14, 2024 | 06:13 PM
CutLS's Avatar
I'm trying to find out what battery group is needed for my 1961 Olds 98. When you search online, it comes up with a Group 27 or Group 24 as an alternative. Well I tried the 27 series battery from work and it's way too wide. The battery tray is just under 6 inches wide from what I measured. Also if someone has a picture of how the battery holds downs setup, that would be very helpful.
Old Aug 14, 2024 | 06:46 PM
The original battery was a Delco R63, which was a Group 60 battery. I doubt those are even made anymore. The Group 60 dimensions are 13 1/16 x 6 5/16 x 8 7/8.
Old Aug 14, 2024 | 07:00 PM
rocketraider's Avatar
Oldsdruid
BCI Group 60K. Long obsolete and available now only as a reproduction.
There are some modern batteries, Group 51 comes to mind, that will work.
Get yourself a 1961 Olds factory shop manual. It will show battery mounting.
Old Aug 14, 2024 | 07:11 PM
Charlie Jones's Avatar
Phantom Phixer
There's this one;
Oldsmobile Antique Auto Battery (1954-1965) S60KL - BCM (batterycentralmall.com)
Pricey, but it is a no hassle fit. Looks righteous too.
If you want to go on the cheap, a group 27 is probably closest to a group 60.
Expect that the hold down will not fit without modification.
And you may need a longer battery cable.
Jon442
May 10, 2021 07:31 AM
Bfg
Apr 20, 2020 07:36 AM
Neil Morrison
Feb 28, 2020 06:35 PM
51Rocket
Sep 2, 2018 10:58 AM
VikingBlue
Feb 11, 2012 10:24 AM
