Are the hi beam stomper switches serviceable?
Old May 19, 2024 | 08:18 AM
Drove home from car show last night with low beams and things were fine. Ran hi beams for some parts, and got some flickering. I stomped back to low beam and then back to hi and it did not happen again.
Specific failure mode:
-ALL hi beams flickered off.
-No adverse behavior running lights or dash lights.
-Hi beam blue indicator flickered in time with hi beams flickering.
I suspect mechanical contact issue in switch on that side due to lack of use. Immediate countermeasure is use switch more and see if problem reoccurs. Can you take these apart and clean contacts? I could deoxit it.
Old May 19, 2024 | 08:46 AM
The contacts are probably corroded, it will probably clear up with more use. No they aren't meant to be repaired.
Old May 19, 2024 | 09:39 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I find that some items that are not intended to be serviced and occasionally be serviced.
Old May 19, 2024 | 09:46 AM
Thanks both, will advise if problem reoccurs and will make cycling switch a couple times be part of driving regimen.
Old May 19, 2024 | 02:26 PM
ourkid2000's Avatar
The original in my '66 Toro was actually preventing the low beams from coming on. I removed it and tried every which way to make it work.......contact cleaner squirted up under the cap, Deoxit, WD-40, tried exercising it over and over with all that stuff and nothing worked. I had to straight up replace it. Everything works fine once again.
Old May 19, 2024 | 03:50 PM
Charlie Jones's Avatar
Phantom Phixer
These dimmer switches are most readily available.
For less than ten bucks. why screw around trying to fix one.
1967 OLDSMOBILE CUTLASS SUPREME 5.4L 330cid V8 Dimmer Switch | RockAuto
Old May 21, 2024 | 02:42 AM
I'm an engineer. Fixing **** is what we do.
Old May 21, 2024 | 01:04 PM
X2. I have this conversation with my co-workers all the time. We'll spend an hour to repair a $10 item, just because we can.
Old May 21, 2024 | 05:28 PM
cfair's Avatar
Be aware that the flickering in those mid-60’s cars can be from the heat sink on the actual headlight switch getting too hot and cutting power.
It’s very likely the floor switch, especially if it’s original, but the light switch needs to be clean, not corroded and in good working order too.
Over the years, especially with high amperage circuits like headlights, I’ve gotten in the habit of using a dremel to clean the the electrical pins on the switch back to not-quite-polished and even pop the contacts out of the plastic shells to clean them. Just for good surface-to-surface contact with a minimum of heat.I think it’s helped and I recall flickering lights in my early years with my ‘66 98.
At the time I didn’t know there was a circuit breaker in the switch, nor did I know that dirt contributed to heat which led to flickering.
Not to distract you from the floor switch, but just be aware the flickering can come from elsewhere.
Chris
Old May 11, 2025 | 08:52 AM
ourkid2000's Avatar
Replaced my dimmer switch last year but I thought I'd have a go at repairing the old, original, 1966 one. Be careful with those pot metal tabs, very fragile. Other than that, should be easy enough to fix.
TahoeRob
May 8, 2023 07:19 PM
1969cutlass4d
Aug 26, 2016 09:18 AM
Olds
Ninety-Eight
Jan 17, 2016 07:58 PM
Raydermiike
Nov 16, 2013 08:31 AM
cutlass47
Nov 6, 2010 07:39 PM
