1987 olds cutlass cruiser: crank but no spark
Hi, i recently purchased my 87 with a no start, figuring that it be a simple fix. However, I have traced wires, replaced ignition coils, ignition coil module, crank sensor and ignition switch. however it is still not starting. any ideas??
Did you verify that you have spark? Did you verify that you have fuel pressure at the test port? Can you hear the electric pump turn for two seconds when you turn the key to START? I'd once again suggest that you stop throwing parts at the car and start troubleshooting first. And which engine is this?
