This is on the heater/AC box, engine side. There are 2 connectors that plug into it, however one of them is broken on the box side. I noticed there are bolts as if it's bolted in, so my question is..can I replace this without pulling the box, or does the box need pulled? If so, what is it and where can I find one?
This is on your Toronado correct? Looks like the connectors for the blower motor resistors. They're on top of the box right? Underneath the cowl by the heater control cable?
*edit* sorry, I confused you with someone else. You have a 442, not a Toro......still looks like blower motor resistor connectors though to me.
I ordered one, received it in, and swapped them out. The coils (not sure if that'd be the correct terminology here) on the back were different from old vs. new, but at least the plugs are actually plugging in.
