What is this, and can it be replaced?
Old Nov 19, 2024 | 09:37 AM
brotherGood's Avatar
This is on the heater/AC box, engine side. There are 2 connectors that plug into it, however one of them is broken on the box side. I noticed there are bolts as if it's bolted in, so my question is..can I replace this without pulling the box, or does the box need pulled? If so, what is it and where can I find one?
Old Nov 19, 2024 | 11:33 AM
ourkid2000's Avatar
This is on your Toronado correct? Looks like the connectors for the blower motor resistors. They're on top of the box right? Underneath the cowl by the heater control cable?
*edit* sorry, I confused you with someone else. You have a 442, not a Toro......still looks like blower motor resistor connectors though to me.
Old Nov 19, 2024 | 02:05 PM
VC455's Avatar
Barely Registered
Fusick is one source, https://www.fusickautomotiveproducts...sp?number=R640
Old Nov 25, 2024 | 04:57 AM
Thanks for the help on it.
I ordered one, received it in, and swapped them out. The coils (not sure if that'd be the correct terminology here) on the back were different from old vs. new, but at least the plugs are actually plugging in.
Old Nov 26, 2024 | 01:12 PM
Oldsguy's Avatar
Past Administrator
Those coils are wire resistors.
Bandit60
Mar 21, 2021 09:40 AM
Bee-Oh-Pee
May 18, 2020 02:17 PM
AMMoyer
Mar 4, 2019 02:37 PM
rcktdoc
May 9, 2014 10:21 AM
jeffs 89 cutlass salon
Oct 10, 2007 05:34 PM
